Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Some water got into my gas can and I put the gas in the mow unaware of it. I mowed for about 30 to 45 minutes when the mow's engine begin to make a popping sound. IWhile draining the gas tank and changing the oil, I notice the oil had gas mixed with it . The engine begins to run steady for a second and then begin to miss and popped again.
    Scholar:
  • 150 Answers
If there is gas in the oil you drained from crankcase the carb is really dumping fuel(did you see black smoke?) If your carb has a drain plug drain it. If not you will have to take off the carb bowl and clean it. Check float operation, turn on fuel work float by hand to make sure gas shuts off when float rises to level position. If not may need needle and seat kit. Or adjust float.
Posted on Sep 28, 2010
I start mowing then a few minutes it will stop mowing. cub cadet zero turn tractor 1050 model 17af9bkbp010
I don't know if the Cadet is powered by a Kohler engine or Yamaha.
You may have a bad spark plug, plugged filter or bad gas.
May 08, 2015 | Garden
Hi, I have a John Deere Z225 with an 18.5 Briggs
Although, this does sound like a fuel issue due to past experiences I want to say the problem might not be fuel at all, but before we go that route try one thing. On that particular model I believe the gas cap is vented, if so try running it till it acts up, then remove the gas cap for a moment and see if the engine returns to running normal, if not I believe your coil is going out. I have seen alot of these engines recently where the works fine but when the get hot they quit functioning all together or only function part of time which in your case would indicate why it is missing and fowling the plug. When these tend to do this after they cool back down they function properly again until they get heated up again. I hope this helps you.
Oct 03, 2013 | John Deere Garden
The engine stops after I have been mowing for about 15 minutes. I remove the gas line from the tank and blow it out in both directions with my air compressor. Mower then runs fine until the next time I...
sounds like dirty gas tank or fuel clean out tank reel goodistall new fuel line install inline fuel filter and clen out carb after this should be ok to
run
Aug 27, 2013 | Garden
I have a cub cadet with 16hp kohler, I changed the fuel line because it was leaking, since then, it will only run for twenty minutes while mowing. I have replaced the fuel pump,filter and had the carb
take a look inside the tank and see if a piece of the old hose is floating around then try it with the gas cap loose the vent could be plugged
Jul 08, 2012 | Garden
Mow rund fine for as few minutes and then shuts off. I have replaced the coil and problem still persist.
My suggestion is to clean your carb and try again. Make sure there is no water in gas tank..
Aug 30, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Jun 09, 2009 | Garden
Poulan Pro model 185H42ST dies after 30-45 minutes mowing
Put a carb kit in it. If that does not work replace the gas cap they are supposed to breath and if they get clogged it will create a vacuum in the tank starving the engine for fuel.
Apr 24, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
315 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
