I need to remove a central ac because move to a diferent house what I need to do? or how can I remove de gas? can I just let the gas go or do I need to have a important proces
  • 2,019 Answers
You can release the freon or capture it with a pump and container. Often companies will come get the freon for you, for free, because they get to then reuse it.
But the equipment is expensive, and I don't know anyone who rents it out.
But I do not really recommend moving central AC. With the hoses, releasing the freon, installation of the condenser and evaporator, the controls and wiring, etc., it is hardly worth it.
A new central AC unit will cost about the same as the labor to remove one. Once opened, you need a vacuum pump to remove the air and moisture that will enter. Not to mention new freon.
Here is a guy selling the outside condenser for $800 and inside evaporator for $400.
http://portland.craigslist.org/mlt/for/1975257657.html
This guy is selling kits as low as $550.
http://portland.craigslist.org/mlt/hsh/1969137182.html
Posted on Sep 28, 2010
When removing a ceiling cassette type air conditioner do i need to remove the gas before removing the ceiling unit
If your removing any type of Ac system, you will want to remove the gas. Some units have a pump down feature as in central units, but i have not seen to many on mini's as most of them use variable speed technology, thus no valves to close properly, just depends on the type of unit you have with what will need to be done..
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Mar 11, 2015 | Heating & Cooling
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Goodman central air conditioning. Little air is coming from the vents in the house and the air that is coming out isnt very cold
have the central unit blower/fan cleaned as they block up from dust and other particles so that they eventually look like logs and do not move air like they should. Have the unit gas pressure tested for correct amount of gas
Jun 17, 2013 | Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
It's flashing code F-28
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. Panne de communication entre le module de commande central et le module de commande du moteur. Possible Causes/Procedure 1. Unplug washer or disconnect power. 2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU). - Check connections of the CCU board within the housing. - Make sure all grounding switches are engaged. 3. Check the drive system for any worn or failed components. 4. Plug in washer or reconnect power. 5. Verify CCU operation by running a Diagnostic Test or any cycle. 6. Check the MCU by looking for operations of the drive motor. 7. Check the drive motor for powered rotations. 8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Nov 26, 2010 | Kenmore HE2 Plus Front Load Washer
Would like to know how to intall an air condition compressor
Firstly de gas the a/c system then remove a/c belt then remove the 2 a/ c pipes to the compressor then disconnect the ac clutch wiring remove the bolts holding the compressor to the cyl block fit new compressor replace the ac pipe orings Then refit the ac pipes reconnect ac clutch wiring refit belt. Then regas the system addind uv dye and comressor oil
Oct 04, 2010 | 2001 Pontiac Grand Am SE
I was given a new light blue Gaggia 'Francis Francis' machine ten years ago. I used it pretty regularly, then put it away during several house moves . I'm trying to get it working again now, after 5...
valve in group head seized. remove 'shower' under group head with central screw remove internal spring loaded jet clean and re-install. Then run a de-scale.
Sep 19, 2009 | Coffee Makers & Espresso Machines
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
DC power adapter
The adapter for the DE-805TP supplies 9 volts dc at around .5 amps
Jan 13, 2008 | D-Link DE 805TP (DE-805TP)5x10 Mbps...
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
