Question about Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator
When I install 2 telephone, the telephones start to dial
I bought 2 telephone, but when I install the 2, the telephone start to dial and at the same time l' operator answers by saying that I must check the number and that I must hang up again. If I test with another telephone it's the samething. If there is only one telephone is ok. which is the problême? The phone compagny came and said the problême is located in my telephones and he said if I want to have two telephones I must buy other telephones.
how ican make to regulate this problême there is
it a solution… thank you
sorry for my english i'm french.
manonlar@videotron.ca
  • gswinamer Nov 16, 2008
    When I hit the talk button on the cordless phone, it automatically dials a number......I tried the Auto IP fix, but it still does it. Of course being a cheap phone, the website for the company is useless.
  • 32 Answers
Might be the IP funtion, not available in the USA. so u being in france, (assuming you are)..it should work. but if that is the problem, try turning off this funtion. press SET/SAVE, press Up to SET 4 AUTO IP, then press SET/SAVE again to select, then press UP to turn on and off, then press SET/SAVE to confirm. hit DELETE to return to main view. i have emailed you a copy of the manual i have. hope it helps.
tammy
Posted on Aug 12, 2008
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Jan 18, 2016 | NorStar M7324 Telephone
How can I setup forward call to my cel from VTECH CS6649-2
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
Jul 14, 2015 | Vtech CS6649-2 Digital Answering System,...
GETTING DIAL TONE BUT NUMBERS NOT REGISTING WHEN DIALING.
Hi earllnoel,
This is a common problem of the telephone unit,you better replaced it.But before you replace it,to be sure that telephone defected already,try a good telephone unit to put there to be sure that's is working.
Regards,
VOTIT
Dec 03, 2010 | RCA ViSYS 2-Line Speakerphone
I need to know if the vodavi 30 button part number 3015-71 needs a lifter for a headset or not
No. It's a programming item and a code or softkey.
The user connects the modular headset to the handset jack on
the telephone leaving the handset in place. The ON/OFF
button on the Digital Telephone is used to initiate and end calls
while using the headset.
To activate Headset Mode:
Dial [634] on the dial pad,
-or-
Press preprogrammed HEADSET MODE button. LED lights
steady.
To deactivate Headset Mode:
-or-
Press the preprogrammed HEADSET MODE button. LED
extinguishes.
While Headset mode is active, the ON/OFF button
activates the headset and disables speakerphone
and intercom call announce operation at your
station.
To install the headset, see the Installation Manual.
Station must be programmed in database
programming for headset operation before the
flexible button can be programmed.
Carl
Dec 23, 2009 | Vodavi 30-BUTTONVODAV XTS Telephone
My Panasonic Telephone Model KX-TSC35JXW dial pad is locked
I am having a Panasonic Telephone Model No.KX-TSC35JXW but I am not able to make calls because it is telling that the dial is locked but i dont know how to solve the problem.Please help me.
Jun 22, 2009 | Panasonic Lands Phones
Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Mar 26, 2009 | Comdial Impact 8024S Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Sakar Telephone Problem
This Telephone doesnt have a capability to work with shared connections where u use more than one phone in one connection.......... And this phone cannot be charged it works in either battery or Adapter...... Good Luck......
Dec 10, 2007 | Sakar Talking Caller-ID Speaker Phone
Programming numbers into telephone
to store a speed dial on the kx-t7730 with the Advanced Hybrid System KX-TA624 you press the following keys
<pick up the receiver>
<the number you want to have as speed dial>
<the number you want to dial>
<press the square shaped key next to 0 and 9>
<wait for dial tone to return>
<hang up>
To call using the now saved speed dial, press the square shaped key and then the number you have saved to speed dial
For example
<pick up receiver> 2*1555555555<square key> <wait for dial tone> <hang up>
This will mean that when you press the square key and 1, it will dial 555555555
Oct 03, 2007 | Panasonic KX-T7730 Corded Phone
Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator Logo
118 people viewed this question
Top Innovage Lands Phones Experts
spiritsoul
Level 1 Expert
Mike Neath
Mike Neath
george  peters
george peters
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
