Bosch & Tankless LP Hot Water Heater  Logo
Posted on Oct 16, 2017
We have a Bosch Gas Tankless Hot water heater Model AQ250. We keep having to push the reset button. Sometimes it works and most of the time it doesn't. The pilot is on, I can see the Furness ignite but the fan shuts off so the machine turns off and flashs AC or EC. As I said earlier it does work fine sometimes and other time nothing. Help!
5 Related Answers
Anonymous
  • 25 Answers
  • Posted on Jan 19, 2009
SOURCE: Bosch 125 Tankless Water Heater - Water not hot enough
Sounds more like the venturi in the watervalve of the tankless water heater is clogged. I would recommed rebuilding it and paying close attention to properly relubing the pushrod and cleaning the venturi.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on May 06, 2009
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jun 09, 2009
SOURCE: The Pilot burner flame is large & yellow
the pilot is getting too much air and is an indicaiot of dirty or air/ fuel ratio imbalance. The pilot is wimpy and the thermocoupler has alot to do with the gas . Make sure your thermocoupler is on the tip of the flame. You may end up replacing it. because it is showing signs of eminnt failure. When it fals your curners won't fire up. Good luck.
Anonymous
  • 332 Answers
SOURCE: Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
john h
  • 29492 Answers
  • Posted on Feb 03, 2010
SOURCE: Bosch tankless GWH 2400 ELP in use 2-1/2 years.
are u using well water or hooked up to city line if well water --may be to cold for unit if water is below a certain temp unit usually goes into error or shuts down if un heated space where water heater is u may have to warm [ insulate ,heat tape etc]the incoming water usually water that around 40 degrees causes problems
Yes you need to delime tankless each year.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Contact Bosch for exact repair information. My records show following number for tankless gas: 800-642-3111
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Will not fire at all, trys to light but get the e1 code . used to work intermitently or fire right of way but then go cold and back to hot for about five min. then stay hot now wont even light
Before calling service technician, open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Bosch_E1_troubleshooting.pdf
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/
http://waterheatertimer.org/Crossover.html
Before installing tankless water heater, read the service manuals and product manual to make sure you have testing skills and equipment needed to repair tankless gas water heater, and that you are prepared to buy expensive parts when needed and do the recommended yearly and monthly maintenance as outlined in manual.
Also check that area has qualified service technician, and that person carries parts on-hand, and is certified for your model number. Keep Tankless manufacturer contact information on-hand, and be skeptical of promises of unlimited hot water, and effortless long-lasting water heating, and saving money. The only folks saying this are the folks selling the product, and not their customers.
Fix most tankless gas water heaters yourself, same day, all brads for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
We have a bosch tankless water heater in a 1600 sq ft home...it works great except in one faucet (the spare bathroom sink)...sometimes the hot water comes out, sometimes it doesnt, sometimes it takes...
Since you have hot water at all the other fixtures, the problem lies in the sink, not the water heater. It could be that the sink is farther away from the water heater than the other fixtures. It would take longer to get hot water.
I have a Bosch Tankless Water HEater Model GWH 2700 ES NG with an error code of A3. I was told to push reset and the problem would be resolved. This worked several times and now it doesn't work. ...
Yes. Contact Bosch.
Error codes are considered start-point for troubleshoot.
Tankless are complex electronic machines.
If on-site plumbers cannot figure out problem, then you need trained service technician with a service manual for your specific product, who can ohm-test the electronics.
Bosch will have a list of trained service technicians. And maybe Bosch has another step for fixing problem yourself.
Fix most tankless problems yourself, same day, for $330.
Gas outdoor mounted AQ250 won't stay lit. Unit is about 2 years old and has been working great.
Before calling service technician, open following link for Bosch troubleshooting resources.
Sample manual has troubleshoot section and yearly maintenance requirement.
http://waterheatertimer.org/pdf/Bosch-250SXO.pdf
Service bulletins for 250SXO
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
Tankless require yearly maintenance as outlined in manual.
No tankless manufacturer suggests do-it-yourself repairs on their product, in part for liability and danger to customers, but for long-term customer satisfaction.
Repairs and yearly maintenance will eliminate the $1-8 monthly energy savings expected from owning tankless.
4helpful
Bosch 10p, the pilot light went out, when reigniting i pressed the shut off button, now it is locked in and i cant release it, is there a reset button somewhere? regards
Bosch Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
For Bosch tankless troubleshoot resources:
For Rheem tankless resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
My Bosch tankless hot water heater keeps turning off and I have to go out and reset it often. I go outside and the screen is flashing A30...I reset it and it works for a while and then it goes out again. ...
Open following link for Bosch tankless troubleshooting resources, including Bosch contact number and link for finding service technician, etc.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Our Bosch tankless hot water heater keeps shutting off. We have been having to reset it more and more. And now it shows 130 on it, but the water comes out cold.
Have a Bosch Service Provider inspect the installation. You can locate one at boschhotwater.com or Protankless.com. It sounds like a very poor installation with poor combustion air and poor gas piping.
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
