Question about Cycling
I was riding up a small bank so that both wheels were on it. i then pused down on the right pedal so i could get the bike in the air to 180 out of the bank. As i did thos i herd a loud crack and when i looked at the back wheel it was hanging off. When i took it to bits there was a small bit broken off the akle. I am now wondering how i get the old axle out now The bike is a 2010 onza comp Thanks
    Sergeant:
  • 270 Answers
The AXLE is balanced in the center of the wheel, and held on by 2 nuts on either side of the wheel.
Remove the wheel from the bicycle and remove ALL of the nuts and washers. You should ONLY have threaded bolt through the center of the wheel.
There are ball bearings in the center that allow the wheel to turn freely.
What you likely did was to break the casing.
Keep track of how you taake it apart, because when you get the new parts, you will have to put it back together.
Of course another option would be to take it to a shop and have them fix it, or get another wheel.
P.S. Please stay in school or use a spell checker, I could barely understand what you were asking.
good luck and don't forget to vote!!!
Posted on Sep 28, 2010
Trek 7300 effort pedaling
If the wheels spin free then I would look at the bottom bracket. All of the force you use for pedaling relies on the bearings in the bottom bracket being good. Are the pedals hard to turn by hand? Do the pedals themselves spin freely? If the wheels turn, this really only leaves these two rotating points as possible suspects.
Sep 17, 2014 | Trek 7300
I have 2007 model pulsar 150 bike, i have driven the bike for more the 45000 KM and now say (after 35000+ KM ) there is lot of wobbling in the handle when the bike speed crosses 50 kmph. I am still riding...
First change the fork cone set for banking problem, next check front and back wheel bearings
(sprocket bearing as well) for wobbling and then stay bush next back wheel damper rubber . Sure this will resolve .
Apr 07, 2011 | 2007 Bajaj Pulsar 150
Hey I'm new to Bikes I have a Yamaha virago 250cc 2003, and there is a tube that runs down the frame behind the front wheel and when I get back from riding a black oily liquid slowly drips out, the tube...
That is either the crank case vent tube or the Air Box vent tube. There is a tube like that on most motorcycles. You can attach a small plastic bottle to the end and it will catch the oil that drips out. I have a small bottle on my 2005 Vulcan 800 Drifter.
Feb 19, 2011 | Yamaha Xv 250 Virago S Motorcycles
No brakes at rear wheel of my 2005 standard goldwing. Had a new rear tire(screw/nail) put on and the service man told me.I normally slow down slow enough to use front brakes.I had installed full foot...
Try putting the bike on the center stand and get the front wheel off the ground with a floor jack. Spin the front wheel by hand and press on the rear brake pedal. The front wheel should stop. Likewise with the bike on the center stand and the rear wheel off the ground you should be able to lock the rear wheel with the foot pedal. On many Goldwings the rear pedal also operates one front disc. This is for people that refuse to use there front brakes to stop or slow there bike (80% to 90% of your stopping power is the front brake). Try bleeding the entire system front and back, you may just have air in the system. If the rear brake still does not work you may have a bad delay valve in the system. If you need to take the bike in to a shop, try to find a mechanic that is familiar with the system so they do not replace parts unnecessarily. That way you minimize your shop time and maximize your riding time.
Aug 21, 2010 | 2005 Honda GL 1800 Gold Wing
I have a broken spoke on the back wheel of my bike, and the wheel wobbles from side to side. Is it dangerous to ride up a steep hill, I need to get home, and am wondering if it would be best to walk it or...
This depends mostly on your weight. Yes, it's safer to walk, but if you are a small person, and you can ride the bike on a level surface (like a parking lot) without the wobble increasing, then try pedaling hard in the parking lot. If that works ok, then you can probably get by. Don't ride fast. Don't ride down a steep hill. If you have hand brakes, and your front brakes are good, then don't use the rear brakes. But don't go over the handle-bars by using the front brakes hard! If you are not a small person, then walk the bike. Good luck.
Aug 09, 2010 | Cycling
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
HELLO.. MY DAUGHTERS POLARIS TRAIL PRINCESS STALLS WHILE GOING UP HILLS. THE BATTERY SEEMS TO CUT OUT, AS THOUGH NOT ENOUGH POWER TO MAKE IT UP A SMALL INCLINE.. I CAN UNDERSTAND THIS, HOWEVER THE BIKE...
sounds like the foot pedal might be bad, when she is driving forward and lets off of the pedal do the rear wheels lock up or does it keep coasting?
Jul 05, 2010 | Polaris Trail Princess
I just replaced my offroad tires on my bike with road tires. Now I have a small, but noticeable, vibration in the pedals when I ride. Is this a derailleur issue?
It could be a d-rail, but also could be spokes, chain rub, wheel hitting a brake pad, tire clearance at frame, bearings.
Put your bike upside down so you can turn the pedals while you check for where this may be coming from.
Take your time... these noises can "telegraph' thru the frame and fool you so look for visible signs, use a little chain lube, oil , etc and you'll be able to pin point your noise.
I had an issue on my high end road bike.. a clicking while pedaling uphill...very annoying... turned out to be the added pressure caused the rear wheel spokes to click at the crossover point... a little heat shrink tubing did a nice alteration without a spoke pressure increase... So look around , start eliminating the possiblitites and you'll find it!
Sep 02, 2009 | Mountain Bike Bicycle Derailleur Hanger...
Pedals don't 'engage' the wheels.
Take off the wheel and slide the red metal cap along the pedal post. Pop off the white plate with a small flathead screwdriver. This will expose the inner hub of the wheel. There should be a small metal plate held to the hub of the wheel with four screws...check the screws...did they snap off? You can also call the Radio Flyer customer service line (8-5) and get some help if you need a new wheel.
Apr 07, 2009 | Radio Flyer Steer and Stroll Deluxe Trike
Men?s Schwinn 700C Prelude Road Bike Assembly
Pedals can be purchased in pairs and some road bikes do not come with pedals. They have 2 different axle sizes 9/16" and 1/2". There are road pedals and road clipless pedals.The ones with clips and quick bindings require special biking shoes that the cleats clip into.Quick releases come in various lengths for front and rear wheels depending on what wheel you have. This all means a trip to your local bicycle dealer. They will match the pedals to the axel size you need and the type of riding you will be doing. For a little extra cost they will install them.They will also match you up with the proper length of quick release skewer you will need and show you how to install and tighten it properly.Remember to take your bike and the front wheel. Hope this helps. Good riding.
Mar 15, 2009 | Schwinn Midmoor Men's Hybrid Bike
Cycling Logo
57 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
