Question about Xerox FaxCentre F110 Plain Paper Laser
Good day, I am writing to express my dissapointment at having to replace our fax, your IF6025., after just five months. A very good machine in perfect working order but using ink cartridges at £50 ea which we estimate print less than 100 copies, just too expensive to use. Now replaced with a Brother offering 500 copies for £18. It is a pity that a company of your strength seems intent on making customers feel foolish, something that my company trading for 65 years would not willingly do. Incidentally I know of other users in this area who have taken the same course of action.\r\nDavid Jackson Managing Director
  • 4 Answers
SOURCE: Loud clattering noise
-Open the Front Cover. -Remove the Toner Cartridge -Remove the Drum Cartridge -Next locate the black gear attached to the end of the Drum and turn it with your fingers. -Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction. -If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
Posted on Jul 06, 2007
  • 2072 Answers
SOURCE: Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Posted on Jan 08, 2008
  • 14 Answers
SOURCE: Streaks on copied paper
You have a failed drum cleaning blade that lives in the drum cartridge. The blade is replaceable as a seperate item.
Posted on Feb 10, 2008
  • 2072 Answers
SOURCE: J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Posted on Apr 28, 2008
How do you only print black, I have only black cartiages left, but it still asks for the other colours.
Posted on Jul 21, 2008
Kenmore 400 washer
do not put so much in it ??
think about what i write?? its for your own good
or you damage the machine
if two people stood on your head how far can you walk
Feb 04, 2014 | Washing Machines
I have bought this particular hair dryer, Revlon ionic 1875,the first purchase of it, I had to take it back for replacement after 2 weeks, got the same exact replica. Now 2 months later, it has just quit...
Write to company expressing how you always enjoyed their brand and detail problem in facts, not emotional tirade. Tell them to please rectify problem or your recourse is to discontinue purchasing their products. Tip: Next time save receipt to copy, all original packaging for at least 30 days. Good luck, and hopefully they can send replacement. If purchased w/credit card, contact the credit card company AFTER you write to Revlon so you can record complaint for credit refund should Revlon leave you "holding the bag". Good luck. Jimmy
Apr 02, 2012 | Health & Beauty
Paper jam 2 but no paper is stuck
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
Mar 28, 2012 | Samsung SF-5100 Plain Paper Laser Fax
I have a Canon Fax Model JX500/JX330/JX200/JX201 machine. It keeps displaying Memory Full, even though I have emptied all faxes that were in the memory. I empty them every day regularly and have never had...
I have not heard of this model before. You are not obviously in the UK. Its sounds like your machine has thrown what we call a wobbly (software problem) However Canon usually have two methods of getting into their software of their fax machines. Lets give you both,
1. Press menu, User data #. This enters service mode. Scroll down to Clear and enter into it. now you will have a list of what you can clear. Go down to All data and enter. the machine will go back to the day you bought it. When it restarts enter your country, data and time etc.
2. Look for a key with a head in a circle (only way i can describe it. Its actually call additional functions. Press it then 28 and press it again. use the same method as above.
Hope that solves your problem.
Good luck
May 13, 2011 | Canon Office Equipment & Supplies
The screen on my lg 50" plasma went white and
The power supply has obviously failed. An Authorized LG agent will advise on repair cost. If it is just the Power Supply it may be not too bad but un authorized technicians do tend to hike the prices up to cover the lack of experience.
Write a nice letter to LG, they may well listen. It's worth a try depending on where your location is. Lean on the age of the set and that you are very dissapointed that such a good named product should have failed so soon.
Good luck.
Jan 02, 2011 | LG 50PG20 50 in. Plasma HDTV
Chevy 1998 Express 1500 8 cyl Keeps blowing ecm-b fuses- sometimes 4 or five fuses within a couple of miles. replaced fuel pump (twice) and fuel pump relay (twice) ran a new wire from the ecm to the fuel...
i have a 1998 3500, with the 5.7v-8, and fought electrical problems for eight months now. i believe it is a problem within the chevy van, because a lot of people complain about blown fuses. my fuse was the ecm-b fuse as well, and after cleaning all the grounds and bat. connections, starter connections, and disabling the a/c circuit, on the advice of another poor van owner i replaced the ignition coil. six months so far, and no problems. this might help you as well. mine did not have any visable problems, but he was persistant, so i did it. good luck
Jun 02, 2010 | 1998 Chevrolet Express
Fax quality poor when recieving fax from samsung scx 4521F
Good Day Sir, Hope my suggested solution will resolve your problem.
Condition: The incoming fax has a blank spaces or is of poor-quality.
  • The fax machine sending you the fax may be faulty.
  • A noise phone line can cause line errors.
  • Check your machine by making a copy.
  • The toner cartridge, referring to "Replacing the Toner Cartridge".
Redistributing the Toner
  1. Open the Front door.
  2. Pull the toner cartridge out and remove it from the printer.
  3. Gently shake the toner cartridge from side to side five or six times to redistribute the toner.
Have a nice day and God bless.
Oct 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Life of a 920?
As long as they still make the ink for them.
Aug 29, 2008 | HP 920 Plain Paper Fax
Zoom lens noise in videos..
1 1/2 years, months, weeks? a little unclear.
you should not hear the zoom motor operate. you should not hear the result of its operation as elements move along.
you have a worn gear or contamination, or other defect. its probably minor. it happens.
return for service. its a good unit. but i would compare repair cost to replacement of latest comparable unit and then explore an upgrade option.
good luck
Dec 24, 2007 | Canon PowerShot S2 IS Digital Camera
Xerox FaxCentre F110 Plain Paper Laser Logo
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
