Question about Danby DWC283BLS Wine Cooler
I own a DWX440BL which is about 5 years old. Only recently, I ended up with warm bottles of wine and noticed the absence of that familar sound coming from the compressor. I turned off the temperature control switch inside the cooler; waited for about half hour, then turned it back on. About a few seconds after, all I heard was a click from the relay switch, and no activity from the compressor. 'Done this a number of times only to get the same result.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to clean the condenser coils, if still not resolved then you'll have to get the start replay and/or overload switch for compressor. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
How to make wine bottle windchimes
17 steps to make wine bottle wind chimes -
1. Gather empty wine bottles, ideally, you're are going to need at least 3 bottles.
2. Remove labels.
3. Wash the bottles.
4. Grab a glass cutter and score around the bottle using a
clamp as your guide.
5. Cut 3 bottles and sand the sharp edges to prevent cuts.
6. Get 3 corks.
7. Acquire 6 3/4 hooks.
8. Buy at least 2 feet (0.6 m) of jewelry chain.
9. Screw the hook on top of the cork.
10. Attach the chain to the hook.
11. Push the cork back on top of the bottle.
12. Repeat steps for the other bottle.
13. For the last or bottom bottle of the chime get a metal earring or any accessory.
14. Attach it to the chain. this will make sounds as the wind blows into your chime.
15. Accessorize the end of the chain if you prefer.
16. Carefully connect all three bottles.
17. Hang somewhere where air passes and listen to relaxing sound it makes!
Mar 12, 2017 | Furniture
I have a 5 year old cuisinart 32 bottle wine cooler that I bought at Crate & Barrel. It does not work any longer - worth it to get it repaired and where - I am in Scottsdale AZ
Contact a local appliance repair shop and get an estimate on repair and then make that decision as to if it is worth it to repair, my vote is no.
Oct 25, 2016 | Furniture
Wining sound when starting but when engine warms up it stops
This has so many variables...is the serpentine belt the original? It can be hardened with age, quiets when warmed up...could be tensioner pulley, this noise could come and go however...also is your weather very cold? If equipped with an automatic transmission, the age can exhibit unique cold sounds...if tranny never serviced, add a bottle of Lucas Oil Transmission Stabilizer to tranny fluid...read instructions, you do not have to drain anything...This is highly recommended for cleaning tranny. Hope this helps.
Mar 26, 2014 | 1999 Isuzu Rodeo
When people talk about wine I have often heard them use the term sediments. What does this mean?
Sediments are basically crud (a mixture of tannins and other solid matter) found at the bottom of an aged wine bottle. They will not harm you in any way. They will however negatively affect the taste of the wine and are best avoided. If you notice a bottle of wine with some sediment, I recommend standing the bottle upright a day or two prior to serving, to allow the sediment to fall to the bottom. When it comes times to pour the wine, simply stop before any sediment comes out.
The link below will further clarify sediment found in wine and how to remove it.
http://www.youtube.com/watch?v=U8XVjdwzsYg&feature=player_embedded
Feb 03, 2013 | Wine & Spirits
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Compressor for haier bc112g
Dear friend,
ngfam at you service! happy to assist!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Haier BC112G Wine Cooler
Haier wine cooler
Dear friend,
Aug 16, 2008 | Haier BC112G Wine Cooler
Danby DWC283BLS Wine Cooler Logo
164 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
