Question about Baby Lock Espire
My bobbin winder shaft is not turning. The power is on and the print out says that it is winding, but it is not. Any ideas?
  • ani_erving Sep 28, 2010
    Sounds like I need to go to the repair shop (an hour away) since I can't even get the screws removed.
  • 11,896 Answers
Almost sounds like a broken gear if nothing is turning.
Remove the two bottom covers, should be one screw for each cover, and inspect the gears. There are two under the bobbin area, and two that drive the feed system.
If you have to change one, and the others have not ever been changed, I would suggest changing them all.
Posted on Sep 28, 2010
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Bobbin on Bernina 807 won't wind?
Please follow the logic checks and possible corrections:
1. Check the winder shaft for a sticking or a stuck condition. If stuck or sticking, add a drop or two of mineral spirits to the winder shaft and the winder support bushing. This will generally release the winder shaft.
If the winder shaft becomes free wheeling, clean off excess solvent and apply a drop of Bernina machine oil which is typically a class 68 machine oil. You can also use a common white mineral sewing machine oil.
Do not use WD-40 or 3 in 1 oil!
If WD-40 had been used prior to the winder seizure then you'll know why....Removing sticky WD-40 residues requires further measures.
2. If only the rubber wheel has hardened, you will need to replace the winder hub with a new hub and replaceable winder ring or the entire winder can be replaced. There are some very good after-market parts available online.
3. If the winder parts are good and you are describing a condition where the hand-wheel will not release so that the machine drives while trying to wind a bobbin, this would requite another question and detailed answer... SewTechnical Home
Jan 25, 2015 | Bernina Sewing Machines
Bobbin winding
put screwdriver in bobbin shaft winder and open the slit a little. also loosen screws that hold winding attachment and move it forward so it just touches the belt then tighten screws. some cheap chinese bobbins slip on winders too.
Jun 18, 2013 | Juki Sewing Machines
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Bobbin Winder Works--Stitching Does Not
The second microswitch that is located just to the right of the bobbin winder stop tells the machine that it is set to wind a bobbin.
If the machine does not indicate that the bobbin winder is engaged, the second microswitch is not the problem. The bobbin winder itself is what shifts the clutch. If it is pulled downward, the clutch is disengaged and the upper shaft does not turn. Place your thumb under the bobbin winder, push it upwards and the clutch automatically re-engages and the shaft will turn.
Be very careful with the touch screen cable with the front cover off. If it has the older style cable on it, they are very delicate when releasing and reconnecting. If you put the front cover back on and the touch screen does not work, this will be the most likely problem. You will need to have the touch screen replaced.
You need to get your bobbin winder turned off first, then worry about the stop contacting the thread. If the stop is not tripped, then it is in its normal position and everything should work fine.
When not filling a bobbin, simply raise the bobbin winder and you should be ready to sew. Look at the opening around the winder shaft in the front cover and you will need to have it up and to the right. Just push the shaft with your thumb.
Mar 25, 2009 | Husqvarna Designer I
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Problem with winding thread onto the bobbin (small free- arm Singer 100 sewing machine). Once bobbin winder shaft is pushed to the right nothing happens-bobbin rod does not start turning so I cannot wind...
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Aug 18, 2008 | Singer Featherweight 140Q
Sewing Machines Logo
130 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
