Question about HP Color LaserJet 2600n Printer
My printer is an HP Color Laser Jet 2600n. When I print it smears and repeats down the page. It also leaves a grey/black tint on the whole paper.
  • 240 Answers
Your cartridges are bad. Whatever colors are causing problems need to be replaced to fix the problem
Posted on Sep 28, 2010
I have a HP Color laser jet 2600n printer. I have tried different Glossy paper, marked for laser jet, but still get bad smudges on my prints. these smudges are still visible on the next ordinary prints...
You need to ensure that you are telling the printer that and your print driver that you are using glossy paper as this will change the speed that the printer prints at and ensure better bonding.
May 23, 2011 | HP Color LaserJet 2600n Printer
I have the Hp 2600n color laser jet and it when i print anything it just repeats all the way down the page like the ink is bleeding
When the printer is repeating text, ghosting, it's usually caused by the fuser. The best way to fix this problem is to replace the fuser in the printer. Depending on how much toner you have left and the price of a new fuser, it might be more cost effective to buy a new printer.
Feb 22, 2011 | HP Color LaserJet 2600n Printer
I'm printing on 110 lb card stock and the toner gets crispy..and actually flakes off on the edges and sometimes leaves smears and clumps of black or burnt toner on the paper. It prints fine on 20 lb paper...
could be the fuser but there is a setting for heavy paper or card stock which will slow it down and increase the heat. depends on your model as to where this can be changed.
Jul 27, 2017 | HP Color LaserJet 2600n Printer
How do one correct print quality in hp color laser jet 2600n
Hi Good day!!
Follow this method hope it helps you!!
During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
Clean the fuser using HP Toolbox
NOTE: Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit http://www.hp.com/support/clj2600n .
1 Make sure that the printer is turned on and in the Ready state.
2 Open the HP Toolbox using one of the following methods.
On the Windows desktop, double-click the HP Toolbox icon.
* On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
3 Click the Troubleshooting tab, and then Troubleshooting Tools .
4 Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
5 Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
6 Click the Clean button to complete the cleaning process. Press the GO button on the printer control panel. The Cleaning page will print, with a second page adhered to the first page. This is normal behavior during the cleaning process.
Cleaning spilled toner
Defective print cartridges can develop leaks. Also, after a paper jam has occurred, some toner might remain on the rollers and guides inside the printer. The pages that print immediately after the jam can pick up this toner.
CAUTION: When cleaning the printer, do not touch the ETB with a damp cloth or with fingers.
Cleaning the paper path
The device features a special cleaning mode to clean the paper path.
NOTE: If there is access to HP Toolbox, HP recommends cleaning the paper path by using HP Toolbox.
Clean the paper path
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Cleaning Mode, and then press (SELECT).
A page feeds through the printer slowly. Discard the page when the process is completed.
3. Load plain letter or A4 paper when prompted.
4. Press (SELECT) again to confirm and begin the cleaning process.
Calibrating the printer
Calibrations are performed at regular intervals. For best print quality, a calibration can be performed from the control panel using the following steps:
NOTE: This will calibrate the color and clean the black electrostatic transfer belt (ETB).
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then press (SELECT). Calibrate color will display on the control panel.
Press (SELECT).
3 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then press (SELECT).
4 Press (SELECT) to start the calibration.
Other options for print quality defects that still persist
Oct 26, 2010 | HP Color LaserJet 2600n Printer
Black cartridge is new,magenta is new blue is halfway and yellow is halfway but the hp color laser jet 2600n prints lighter and black prints as it is finished
Hi Good day!!
Press (SELECT).
Oct 26, 2010 | Office Equipment & Supplies
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Smudges on right ride of paper
want the answer to this we have a hp 2600n laser printer and its leaving smug of color on the paper the big wide roller where the page gets printed is smear with all the colors. Is there a way to clean this and what to use so we can fix the problem.
connie petrik mu email address is connie.petrik@att.net please give me a answer to this problem.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
HP Color LaserJet 2600n Printer Logo
271 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
