Question about GE XL1800 1100 Watts Microwave Oven
Microwave turns on everything works but is not heating up food what can I do, I am a license electrician is there a fuse in side?
  • firstatcall Sep 28, 2010
    Trying to figure out how to remove panel on microwave please help!
  • GE Master
  • 1,711 Answers
Yes if you remove panel you will find a capsule with a ceramic fuse inside so you can check it out.
Many times the fuse blown out from long time use, however if it will blow out you need to check what was the reason for bowing the fuse.
Posted on Sep 28, 2010
It does everything except heatinig up food. Model # JVM 3660 SD 001
The magnetron is not working. This open it and check to see if it has a blown fuse. Some microwave would have seperate fuse for the heating power. If fuse is good. You may be able to get a used magnetron from another microwave. Somtimes pawn shops would sell microwave for 5 or ten dollars just because it doesnt have a turnplate inside.
Jul 07, 2010 | General Electric Microwave Oven
Microwave works but doesn't heat food.
check if it heats through a different outlet by its self if not element is shot but if it works you need a better electrician unfortunately because you might have a new fire hazard with incorrect wiring but thats really only way to find out
May 07, 2017 | Amana MVH210W Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Microwave will not heat food but everything else works.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Nov 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
Everything seems to work but it does not heat the food.
Jul 30, 2009 | GE JVM1650 1000 Watts Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
677 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
