Question about Whirlpool Duet GHW9150P Front Load Washer
Creaking noise when washing cycle. is this the bearings?
    Top Expert:
  • Whirlpool Master
  • 75,066 Answers
Yes this model has a real problem with the washer drum bearing. there are many class action law suits on this, when it gets really bad grease will start getting on your clothes
Posted on Sep 28, 2010
My Bosch classixx 1000 is still working ok, but when i turn the drum by hand to wipe it after a wash, it seems to be getting a bit stiffer to turn, and alsomakes a creaking noise.
Sounds like 1 or 2 things the easy one is you may have a small clothing item stuck in between the inner and outer drum the other is it could be the main bearings getting tight because the are worn out .hope this helps
Mar 14, 2017 | Bosch Washing Machines
Just bought a ford ba wagon and when you do a hard turn like driving in your driveway or turning in a street it makes a loud creaking noise coming for the front
check the strut or top strut bearing for failure
the creaking noise can be from the spring being wound up from turning as the bearing has seized
have it inspected by a specialist suspension shop
Nov 16, 2015 | Ford Cars & Trucks
Creaking noise from front left when turning
check the wheel bearings and adjustment. check cv joints.
Mar 26, 2014 | 2006 Ford Mustang
Maytag quiet series 100 noise during washing
Roaring noise must also come during the spin cycle I suppose...it seems your bearing and or drive belt/gear is causing you this noise. To fix this, you would need to completely disassemble the washer and inspect the bearing and or drive box that activates the turning motion. It is a large job.
Dec 02, 2013 | Maytag Washing Machines
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Creaking and grinding noise when turning steering wheel
Were the top strut bearings changed?
You don't turn the steering wheel, unless
your have the vehicle moving or off the ground
Do you flush the power steering fluid every 3 years,
when you do the trans fluid every 3 years?
Aug 28, 2012 | 2000 Lexus Gs 300
My zanussi machine has started making a very loud noise since it was moved out to replace the flooring underneath (not a big deal) but this has worsened with violent shaking and creaking sounds during the...
Clothes with dark streaks or marks are often the result of a drum that is misaligned due to worn rollers and/or bearings. It's also possible that the drum is out of alignment due to the move (especially if it was tipped at a considerable angle). Try lifting and gently turning the drum to see if you can isolate a squeak or scraping noise that would point to the misalignment.
The marks happen when clothes get pinched between the moving drum and the stationary part adjacent to it.
Good luck from Detroit, MI.
Jul 18, 2011 | Zanussi WJS1397W Front Load Washer / Dryer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Describe your Maytag Neptune MAH5500B Front.loader...Creaks when washing
Hello saber396
welcome
Here are some facts that may be the sounds!
You said. you noticed lately that I hear a creaking sound when it is in the wash cycle...Is that a motor problem?
Clicking/draining sounds
when washer is started will be
before the washer starts to fill, it will make a series of clicking noises to
check the door lock and do a quick drain.
Could it be a rapid snapping and/or
popping sound from the rear
of the washer during spin.
means that
Water is being extracted through the drain holes in the spinner and is
hitting the outer tub before draining out of the machine.
Let me know if these help any one understand the sounds!
Huuum
Please remember to leave a rating!
Jun 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
180 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
