Question about Sony Cybershot DSC-T200 Digital Camera
Broken lock Spring hinged door on bottom of camera won't lock.  Toddler son dropped it on ground, broke outside half of plastic grey lock.  Any fix?
  • lhan26 Nov 01, 2008
    was any part available for this? My latch broke and now the door won't stay closed.
  • sunnypunjani Nov 10, 2008
    the lock door latch broke i don't know how and i hate taping it can i order a new door ?
    Genius:
  • 2,985 Answers
Gaffer tape is the best bet
Certainly you wont get parts in my view.
Though it may be worth a question to Sony Support - some models might -
Posted on Jun 13, 2008
How do I remove the front passenger door on a Citroen c5
Examine the hinges. They may be bolted from the outside at the door side. Another option is remove the 'drop pins' holding the two half's of the hinge together. Some hinge pins are only held in with a spring clip. Your only other option is to remove the front wing and unbolt the door with the hinges still on.
To remove the pins-
NOTE THIS IS A TWO PERSON JOB!!
Proceed as follows...
Support the weight of open the door.
Tap the spring clip sideways off the thin end of the pins,
(located top of the top hinge and bottom of the bottom hinge).
Tap the bottom pin upwards then the top hinge downwards.
You might need to wriggle the door to get them to move.
REFITTING
Put the bottom pin in first as it 'drops' in and the upper pin pushes up into position.
Again, you will have to wriggle the door and GENTLY tap the pins into place.
Swopping the the pins makes it easier to line up the new door as it closes.
Dec 26, 2017 | Citroen Cars & Trucks
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
Dor hinge repair
I fixed my Fagor disgwasher spring last night. The symptom was a bang and the door got heavy. Investigation revealed a broken cord. The parts are available at around 20 UK pounds per pair. They consist of a cord with plastic mouldings at each end. A heavy duty spring sits inside the washer parallel to the door bottom and is streched as the door is opened. I would not recommend buying the spares as getting them off the spring is almost impossible. I had a vice with tools and gave up. Instead I bought some similar cord (try a ships chandler/dinghy shop), one metre should do (99p). Remove the spring and cut the cord off at the moulding. Put the spring in a vice and drill out the cord. Start small (2mm) and work up. Put the new cord through the hole. Bend the spring and use a small screwdriver to fish out the cord. Tie a knot in it. Take a large flatblade screwdriver and open up the coils so the knot will pass through. Drill the other plastic moulding and repeat. The cord length between the mouldings was 280mm but measure the unbroken one. The dishwasher I had a cover clipped in place at the bottom of the door. Lever this forward and the spring is easy to remove.
Apr 18, 2014 | Fagor Dishwashers
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door is locked, wont open
remove bottom acces panel 1/4 screw sometimes torx bit ubplug washer reach in on non hinge side against doorshould be door lock latch assymbley, bottom of latch assymbley is a round plastic end thats spring loaded ,pull downward and open door replace door lock assymbley
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Broke the hinge on my Samsung Alias 2. Need to repair it - have the parts! I had earlier broken my LCD and took the ****** apart, and put a new LCD in. Works fine, but not all of the original screws and...
The spring goes under the little plate that is held in by two tiny screws. Its visible when the phone is open vertically with the plastic cap removed from the hinge. Hope this helps. I took my hinge apart after I dropped it and the top half came off... now it's just holding by the ribbon so I'm going to order a new hinge. Verizon is completely useless. They don't want to even know about you if you're phone isn't under warranty and I have 11 months till an upgrade...
Jun 29, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
Door falls clear to bottom when opened almost got foot broken it was repaired by sears 2 years ago now broke again Elite mod=665 16982201 ser=fp2401121
one of the nylon rope which connects the door hinge to the door spring is broken.usually with time the rope wears out and break.it is preety easy fix. u have to pull the unit about half way out and look for ropes on lhs and rhs bottom of the unit.buy the rope kit(it comes with 2 ropes and plastic roller unit.). just see the one which is not broken and accordingly install the broken one.usually u dont have to install the new rolers unless they are broken.
Aug 26, 2009 | Dishwashers
Dishwasher ''soft drop door'' mechanism came apart - door now drops
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Feb 10, 2009 | Dishwashers
E20
the door won't lock, then i broke the grey thing that the door prong or latch locks into by slaming the door. its a little plastic grey hole hole. i don't see what holds the grey plastic thing in the hole. or how to order it. can you help. ? but the door wouldn't lock before that, i think the 3 and 4 year old kids play hanging on the door. how do you fix it. 2006 afinity fron loader washer. thank you. cheryl
Oct 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Sony Cybershot DSC-T200 Digital Camera Logo
96 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
