just wondering how you connected the amp . you should do the following steps
1 battery cable with right size fuse at battery
2 remote wire from radio
3 rca cable from audio out from radio
4 ground the amp to a good clean piece of metal
then make connection on the amp
1 battery or power cable to the 12volt connector on the amp
2 remote wire to b+ or rem on the amp
3 rca cabel should be pluged in the channels are using cause you tell me that the amp is 4 channel
from the model numbers
4 clean and scrape off paint on the metal surface you are going to install the ground cable from the amp . make sure your ground is no more than 12 inch max. and is the same gauge as the power cable
5 . run your speaker wires to the amp and make sure your ohm load for the subwoofer is 2 ohms or 4 ohms to make the amp work proper .
if need help on anything email me @
[email protected]
