Question about Lexmark C752FN Printer
Lexmark c752 how to clean scanner mirrors lexamrk c752
  • wayne churchill May 11, 2010
    Can you get me the model number off the scanner unit.
    I wouldn't recommend removing the printheads (scanners), Firstly lexmark don't recommend cleaning them, if there's a problem they suggest replacing them. Secondly if you remove any of the printheads you will have to realign it both manually then electronically. If you have a problem remove the toners and clean just what you can get to.
This unit has a scanner on top of the printer.It can scan fax print.I would like to clean the mirrors on the scanner on top of the machine
Posted on May 24, 2008
How do I replace a fuser on a Lexmark C752?
por open right hand door drop lower door on fuser is two green leavers pull them to middle take old fuser out and replace the same way
Sep 21, 2011 | Lexmark C752 Printer
Lexmark C752 printer The printed image is blurred, looks like out of focus and the colors do not seem strong enough? any ideas ?
first check the toner level ? is it correct?
the blur can be caused by a dirty LASER UNIT remove all the cartridge clean properly the two laser unit.
if need another help i'm here and tell me me if your problem was resolved or not.
Oct 28, 2010 | Lexmark C752 Printer
I lost the cd installation to my Lexmark X5470
Look on the Lexamrk web site:
Go to www.lexmark.com then navigate to your model and obtain drivers, software, etc.
Apr 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark C752
if you just run blank sheet through the printer using the printer feed button it should remove any ink on a roller. which probably got there from printing off a picture.
Apr 15, 2009 | Lexmark C752 Printer
Lexmark c752 color is not aligned properly
Make sure that color calibration has not been disabled
in the Diagnostics menus, especially if the printer has
been previously serviced.
Mar 24, 2009 | Lexmark C752 Printer
Lexmark x632 scanner error(046005 adf lamp failure)
There can be a few causes of this error:
1) Firmware Revision is not latest and lamp warm-up time is too short - update firmware first:
http://support.lexmark.com//printerfirmware/
Type in: b103scan
2) Flatbed Lamp has failed and needs replacing.
3) ADF Optical Assembly has failed and needs replacing.
4) Most Common Cause:
ADF Optical Assembly Mirrors are dirty and need to be cleaned - Remove plastic cover from ADF and then remove ADF Optical Assembly. Remove the screw from one end and slide out the two mirrors - clean these and the mirror which is fixed.
Cheers Ross.
http://www.reboot.com.au
Jan 27, 2009 | Lexmark X632 All-In-One Laser Printer
Service printhead error 108
Error Code(s) Printhead Color
106, 111, 115, 171, 172 Cyan
107, 112, 116, 173, 174 Magenta
108, 113, 117, 175, 176 Yellow
109, 110, 114, 169, 170 Black
Power off the printer, take the Magenta cartridge out, take a lint and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. I just did it and it took me three minutes to clean with toilet paper rolled up like a cigarette.
My printer is back on line. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. This has happened to me before with a different color.
here is the Lexmark c750 support link:
I hope this helps. - This is from Joey V on fixyourownprinter dot com
Oct 13, 2008 | Lexmark C752 Printer
Lexmark X422MFP Error 944
Removed CCD ribbon cable, cleaned edge connector and re-connected. Working well so far.
Jun 24, 2008 | Lexmark X422 All-In-One Laser Printer
Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch.  The first thing the we do (and have had great success with) is to clean the laser lenses.  Then check the head wiring.  The following codes apply:
106 & 110 CYAN 107 & 111 MAGENTA 108 & 112 YELLOW 109 & 113 BLACK
Jan 10, 2008 | Lexmark C752 Printer
Lexmark X422- error: "942 service scanner failure
According to Lexmark,one or both of the CCD lamps in the scanner have failed, or the CCD cable is loose or bad.
Feb 07, 2007 | Lexmark X422 All-In-One Laser Printer
Lexmark C752FN Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
