Question about GPS
How to install plasmaglow led thunder grille kit
  • yadayada
    yadayada Sep 28, 2010
    in what?
How do I hook up my MTX 300XD thunder amp to my car stereo.
You have alot of work ahead of you. If you haven't installed an amp before, you may want to have a stereo shop or your regular mechanic install it. There are amp install kits available at most auto part stores. Also, if it's a stock stereo, there are adapters you can use to pull signal from your stock speakers.
Dec 04, 2012 | Cars & Trucks
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 | Garden
Which is the right rotisserie for the Brinkman 8534 Gas Grill? Where can I purchase it and how much does it cost?
You can find and purchase the rotisserie on Brinkmann's website. Click on the Accessories tab and then enter the correct model number for you grill.
http://www.brinkmann.net/home.aspx
May 14, 2011 | Grilling
Nothing fits as it should, I would like to find a step by step install vidio for a part number 71405 shadow billet grill by putco. thanks mb
Congratulations on your purchase of a high quality PUTCO product. Should you need any application or technical assistance feel free to call us at: 1-800-247-3974 Monday-Friday 8:00 a.m.- 5:00 p.m. (Central Standard Time) Contact your PUTCO dealer for other quality accessories. PUTCO Inc. - 216 West First Street - Story City, Iowa 50248 PLEASE READ ALL INSTRUCTIONS BEFORE INSTALLATION AND TO CHECK TO SEE THAT ALL PARTS ARE INCLUDED. Please consult your Vehicles owners manual for vehicle air flow restrictions Putco is not liable for any vehicle damage resulting from the installation of our Grille inserts (71101) 99-02 CHEVROLET SILVERADO / 00-06 TAHOE/SUBURBAN, (71107) 01-02 CHEVROLET HEAVY DUTY, (71102) 99-02 GMC SIERRA/YUKON, (71102) 01-02 GMC HEAVY DUTY, (71104) 99-03 FORD F-150 (71137) 03-06 CHEVROLET HEAVY/LIGHT DUTY, (71138) 03-06 GMC HEAVY/LIGHT DUTY, (71189) 07-UP CHEVROLET LIGHT DUTY, (71163) 07-UP CHEVROLET HEAVY DUTY, (71158) 07-UP TAHOE/SUBURBAN/AVALANCHE, (71190) 07-UP GMC SIERRA LIGHT DUTY, (71164) 07-UP GMC SIERRA HEAVY DUTY, (71159) 07-UP GMC YUKON/YUKON XL. Step 1: Remove the factory plastic hood that covers the area between the grille and radiator by removing the plastic plugs or screws that fasten it in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 3: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 4: Reach between the grille and radiator and reinstall the bolts, plates and nuts onto the grille insert. Step 5: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71105) 99-07 FORD SUPER DUTY PICKUP AND 00-05 FORD EXCURSION, (74105) HORIZONTAL SIDE VENTS Step 1: Remove the four factory screws that hole the top of the factory grille in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 4: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. If you have purchased the side vent pieces install them at this time. NOTE: The installation bolt will go though a hole in the side vent that is closest to the center grille section. Step 5: Carefully pull the grille forward and reach between the grille and radiator, install the bolts and mounting brackets onto the grille insert and/or the flat washer and nut on the side vent pieces. Step 6: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71103) 94-01 DODGE RAM, (71132) 02-05 DODGE RAM, (71156) 06-08 DODGE RAM, 04-UP FORD F150 AND 08- UP FORD SUPER DUTY Step 1: Remove the bolts and mounting plates from the bag kit. Step 2: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 3: Reinstall the plates and nuts onto the grille insert. (Verify that the bolts do not come into contact with the radiator) Step 4: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. Note: Please adjust horizontal blades if irregular. This is the result of shipping and handling outside of Putco's contro
This is the installation instruction sheet for your grill.
Apr 16, 2011 | Ford F-250 Cars & Trucks
Where can i get a kit or info to change a genesis gold b lp 110101 to natural gas.
Give their customer service department a call at 1-800-446-1071 and they'll be able to tell you if the conversion kit is available for that specific grill. If the grill is old, there may not be a kit. In that instance, you could simply purchase a new grill, or try one of the specialty grill shops that sells replacement parts.
Mar 03, 2010 | Weber Genesis Gold B Grill
Can I convert my Frontgate 38" Series 1 natural gas grill to burn on tanked propane?
hi my name is mark, i called frontgate they can ship you the conversion kit. the phone # is 800-537-8787. i would have a professional install the kit. thanks for your question.
Mar 05, 2009 | Frontgate Professional 38" Grill
Charcoal grill to propane
Shouldnt be a problem, the sell replacement kits for propane grills at most home improvement stores. Just buy the replacement kit and install it into your grill.
Jan 29, 2009 | Sport & Outdoor - Others
Ptac grille
Call up this company and they will send you a easy installation kit its about $15 and sure beats fiddling around with the grille. www.airventproducts.com
Jul 22, 2008 | Heating & Cooling
Onida Ky Thunder tv blackout
my onida ky thunder giving fault led blinking after plugin and after 5 second goes to stopped mode
May 11, 2008 | Televison & Video
GPS Logo
148 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
