Can you set the Canon PIXMA MX 870 to print a confirmation page after every fax sent?
  • Office Equip... Master
  • 5,101 Answers
Yes. Press Setup and navigate (right/left arrows) to Device Settings. Then press OK. Next navigate to Fax Settings (up/down arrows) followed by OK. Select TX Report (again the up/down arrows followed by OK). Select the Print for each TX option (up/down arrows) and press OK again. Then press Fax to return to the standby mode.
I hope this helps.
Posted on Sep 28, 2010
  • nevadashaw Feb 13, 2011
    I wonder if it's possible to see a confirmation (that the fax was indeed sent) on the LED screen without printing a report. I'd like to know the fax was received but don't want to waste ink
  • Cindy Wells Feb 14, 2011
    The default TX report setting for the MX870 is to only print a report when an error occurs. If you leave it in that mode, then you can probably assume that the fax was sent if you do not see a report print.http://www.usa.canon.com/cusa/consumer/p... (search Fax report)
I WANT TO PRINT FROM MY MX 870 AND IT WANTS TO SEND A FAX INSTEAD
I had this problem too. I discovered that my printer, with it's regular picture, had somehow been renamed as a Canon PIXMA Wireless Fax even though I already had it listed. Not only that, my Canon wireless printer was no longer listed. I deleted the new fax that was also listed as my default printer, and searched for my printer. I made it my default printer again and all worked as it should. I have a feeling this is happening with the latest driver updates.
Mar 17, 2011 | Canon PIXMA MX870 Wireless Office...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Automatically receive a confirmation page after sending fax
please ser send my experties your machine model then i shall help you
Aug 05, 2009 | Canon ImageRUNNER 1670F Copier
How to have fax confirmation sheet print
open both one-touch speed dialing panels--press DATA REGISTRATION >set> press search buttons to display REPORT SETTING >set> search to OUTPUT YES (This will print a report with every transmission, next option will give you the option of whether to print the first page of the document (yes) to remind you of what it contains)
Mar 18, 2009 | Canon LaserClass 9000L Plain Paper Fax
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax Confirmation on a Canon MP830
To print a TX (transmission) report after each fax sent:
1. Press the Copy button if that light is not already lit
2. Press the Menu button
3. Press the Right arrow to get to "Maintenance / settings"
4. Press the OK button
5. Press the Right arrow to get to "Device settings"
6. Press the OK button
7. (You should be at FAX SETTINGS) Press the OK button again
8. Press the down arrow to get to "TX settings"
9. Press the OK button
10. Press the down arrow to get to "TX report"
11. Press the OK button
11. Press the down arrow to get to "Print for each TX"
12. Press the OK button
(You can have the machine print the first page of the fax with the report if desired)
13. Press Stop / Reset
Apr 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Feb 20, 2008 | Canon FAXPHONE L80 Laser
1,060 people viewed this question
k24674
