Question about Fossil Digital Sport DQ1142 Watch
How can i adjust the time? - Fossil Digital Sport DQ1142 Watch
    Sergeant:
  • 270 Answers
Press and hold the MODE button for 3 sec.
One of the features on your watch will start flashing, press the button again, if the flashing stops, repeat last step and select another button while the display is flashing
Most watches have 4 buttons, lower left is mode
upper left is toggle between features
Upper right set counter cloclwise
Lower right set clockwise.
good luck and don't forget to vote!!!
Posted on Sep 28, 2010
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Sep 08, 2011 | Casio Gshock G Shock Analog Digital New...
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
I could not adjust Analog time of my G-300 Casio watch, however digital time adjusted, please guide me how to adjust analog time.
Pull the crown out. There may be a couple diferent stages (one step for time next step out for date etc)
Jan 25, 2011 | Watches
Time / date adjuster on my Seiko SNAA63 falls out
Sounds like the mechanism that hold the adjuster in is damaged, im afraid you'll have to get it fixed again
Jun 18, 2009 | Seiko Chronograph SNAA63 Gents Watch
How do I change the time on my tissot touch watch
you can adjust the time by rotating the nobe at the back side of your clock,if it is a digital clock it has a button to adjust time ,press the button and see current time and adjust it
Apr 01, 2009 | Watches
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
Adjust time on casio telememo 30 watch
how to adjust time on casio telememo watch
Oct 26, 2008 | Watches
Kenneth cole reaction
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Jul 16, 2008 | Kenneth Cole RK5034 REACTION
Analog will not sync with digital
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Regards,
Tahir Khan
Feb 14, 2008 | Watches
Fossil Digital Sport DQ1142 Watch Logo
182 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
