Question about Frigidaire Refrigerators
The ice maker is not working, Replaced the metal piece that pushes the ice out to the door and now the tray will not fill up with water again, but the water still comes out the door.
  • allen_stanto Sep 28, 2010
    The lever goes up and down and is inside the cover, does the front cover snap on and off to look inside there and the connections are hooked up, should i unplug them and reconnect them?
  • 270 Answers
Hello Sir:
Double Check your Connections and make sure that the Lever that starts your Ice Cycle or Stops it is Connected Properly,It a easy fix just something thats not quite right in your Connections..The Water Will not fill up trays if that lever is not connected right.
The only other problem that can cause this is the Thermastat to your ice maker.Not sure if you have a Rest Button Or Not.
THANK YOU D_HUBBS
Posted on Sep 28, 2010
  • David Hubbard
    David Hubbard Sep 28, 2010
    Sir, Could you Please send me the Model # --Serial # and the Make of your Refrigerator?
    Thanks D_HUBBS
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Replaced ice maker in kenmore elite last year. stopped working again.replaced ice control sensor boards,still nothing.replaced module,poured some water in tray,freezes,rake starts down,hits ice then does...
the rakes can only move the ice if the tray has been heated .. there is a heater mounted on the tray that may be bad or not getting power . here is the sequence that should happen
the water solonoid operates to fill the tray (you should hear it click when this happens) .. then the tray is left alone until the cubes have frozen .. then the heater comes on to free the cubes from their mold then the rake operates to scoop out the ice .. the rake cant move the cubes unless they have first been freed by the heater .. it sounds like you have power (rakes moved) but its not clear if the water fill function is working .. even if it wasnt, if you filled the trays then it should still work but you would have to wait for the complete sequence .. you can feel the heater get hot at the right time if its working (just before the rakes move) .. its a bent tube structure mounted on the ice forming pickets .. be careful it can get pretty hot .. i cant tell but if several things are not working like it doesnt fill with water and the heater doesnt come on ever then that sounds like a connector not fully connected or damaged .. or perhaps a bad (new) module (broken solder connection or otherwise damaged) .. .. you can check the heater with an ohmmeter . it should read low resistance between hot terminals .. and open from ground to either terminal ..(power off and disconnected of course) .. make sure the heater is indeed plugged in ..
Oct 16, 2009 | Refrigerators
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Oct 23, 2007 | Kenmore 53603 / 53606 Stainless Steel Side...
No ice...different question
Are you able to see if you can push a Q-tip or something up the fill tube line to see if it's frozen up inside there. It happens on certain units. You may need to take the Ice Maker out (easy) to get to the fill tube.
Feb 27, 2007 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
44 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
