Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Tv wont start
Sony tv light keeps flashing but no picture
  • 1 more comment
  • capicu Jun 08, 2008
    i have a 62 inch sony wont start . standby light blinks.
  • Anonymous Jul 06, 2008
    hi Sony trinition 1998 kv32s40 tv wont start stand by light keeps blinking.. Do you have any ideas regarding this? Or estimated cost to repair? I appreciate any help you may offer thank you..
  • ram149 Jul 06, 2008
    Im having the same problems, the standby light just blinks 5 times. When I turn on the TV, it sounds like its going to work but it just goes to standby. Dont hear any clicking when the light is blinking though. My friends brother and sister(1-2 yr olds) tend to play with the buttons on the TV. Could they have set the timer?? How do I fix this problem??
  • 790 Answers
Hi
did you hear the click sound when it blinking?
Thanks!
Posted on Jun 22, 2008
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Sony tv wont start up???
It seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). Do you hear any clicking sounds?
Or else it could be that the CRT tube is faulty and will need to be repaired/replaced.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise.
Hope that helps!
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a Sony kf-50we620, It started having problems this week. Sometimes, not always, I turn it on, the green light flashes and the TV will eventually start but it takes over 2 minutes to start. I will...
Its symptoms of weak lamp that need to be replaced.
How old is this TV and did you replaced its lamp recently?
lamp replacement is easy and would be written in user manual. Please buy Sony original lamp for TV safety.
Thanks.
Jan 15, 2010 | Sony Grand WEGA KF-50WE620 Television
It keeps flashing between flashing lights regards
Hi.
The TV stays in standby because protection circuit kicked in.
Protection kicks in when an internal fault had been detected.
In your case the SCART cable may have caused a short.
When on protection the TV will stay in standby, will not respond to buttons or remote, and will not start up.
All higher voltages from PSU get shut down by controller board, and only the +5V remains on.
To attempt resetting the TV, disconnect all video cables, disconnect the power cord, wait about one hour and plug it back.
If TV does not restart, then there may be an internal fault.
In that case leave TV unplugged for longer, just in case.
If still no luck, then call Sony to discuss a repair. The number is listed on your owner manual.
If instead TV will restart, do not use the faulty video cable again, this can damage your TV.
Regards
Nov 06, 2009 | Sony Televison & Video
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The flashing should be a repeated number of blinks. Please post that count as that will indicate the circuit in which the set detected a problem. The set is in protective shutdown. Using hte blink count, we can determine the possible problem and solutions.
Dan
Jun 18, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Projection tv wont turn on
a sony should only blink up to 8 times. If its continuous without any pause that usually means No reply from the jungle (data bus is busy, shorted to ground or held
high), IK video path is defective.
Count your blinks again. let me know.
Jan 21, 2008 | Televison & Video
SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
