Question about Linksys Wireless-G WRT54GS Router (e125894)
I always have to unplug and then plug in my router in order to get connected to the internet I have Roadrunner
  • Linksys Master
  • 6,487 Answers
Base from the description of your problem, this is an issue with the firmware of your router so to correct the problem on it the best thing to do is to update the firmware of it.
Follow the step by step procedure on how to upgrade the firmware of your router from this link, just click HERE.
Posted on Sep 28, 2010
Ok.....my internet is up and running......and im useing the SB5101 Model...but when i switch it back to my SBG900....it gets stuck on the roadrunner (internet provider) web page.....it works fine with the...
Turn the cable-modem off.
Unplug the AC poewr to the cable-modem.
Turn the router off.
Unplug the AC power.
Reconnect the AC power to both the cable-modem and the router.
Turn the router on -- this off/on sequence should "reset" the cable-modem and the router.
If the router still does not work, replace it.
If the cable-modem does not work, get RoadRunner to replace it, if they want to keep you as a paying customer.
Jun 26, 2011 | Arris SURFboard SBG900 Wireless Router...
We just got a road runner cable motem, and I had a linksys router before we got the road runner. I have a dsixl, and it's not connecting to the linksys anymore. please help.
Unplug the roadrunner cable modem completely as well as the Linksys. Let them sit for 20 minuets or so and then plug in the roadrunner modem first. Let it power up completely and then connect the linksys via the internet or wan port.
Check for connectivity.
If no internet connection enter the linksys control web page usually at 192.168.1.1 and perform a ip address release/renew on the status page.
If you do not know your admin login for linksys the default is admin with a password of admin. If you are unable to access the router then perform a factory reset on the router.
Make sure the router is powered ON. Then Press+Hold the Reset button of your router for 30secs first. (Reset is found on the back panel of your router, you have to use a pen or a paper clip to press the button) For the LED's if the power blinking that indicates that the router is being reset and then power-cycle the router for only 30secs.
If the Power LED won't blink Press+Hold the Reset Button for 1min and then Power-cycle the router for another 1min. Then check the IP address of your PC then try accessing your router's GUI admin console using a web browser with the address of 192.168.1.1 and use admin as your password.
Mar 13, 2011 | Linksys WRT120N Router
Setup with roadrunner
Connect Router - Desktop
Open RSP By typing 192.168.2.1
On the Left side under Internet WAN Click Connection
Type
Leave the password blank and click Submit
The Connection Type Should Be Dynamic
Click Next
There should not be any Host name & Click apply
On the left Side Click MAC Address Under Internet WAN
Click Clone And Click Apply Changes
It Should Work
Dec 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Router causing internet connection to fail intermittently
There are a few things can make your wireless router to lose your connection. I like to start with the most simple things first. First clear Out any clutter on your browser. If your are using Internet explorer, go to tools click delete browsing history. When the box appears, clear out the first 3 things. History, Cookies, and temporary Internet files. Firefox, you click on tools, clear private internet files.
After than do a disk cleanup.
In start menu, go to all programs, accessories,system tools and select disk clean up. After this unplug Cable modem's electric cord, unplug the power to your wireless router, leave it unplugged for a couple of minutes, Then plug in your modem,router and restart your pc in that order. If that doesn't work you can always change you network name and WEP key, Hope this helps, also I was assuming you are using a PC and not Mac.
Jul 28, 2009 | Linksys Wireless-G WRT54G Router
Need instructions for setting up internet connection in OS 8
you can contact on roadrunner technical support phone number for getting help. they solve your issues and provide instruction for setting up internet connection in OS 8 Roadrunner Technical Support Number
May 19, 2017 | Apple PowerBook G3 Mac Notebook
I loose internet everytime the phone rings
Absolutely. Wireless LAN is on 2.4GHZ. You will want to get a phone at a different frequency.
Apr 05, 2009 | Belkin Computers & Internet
Linksys wireless was fine on my lan line now cable it is not?
Lets see if this works out for ya.
1. In your browser go to http://192.168.1.1
2. The user will be "admin" and the password field leave it blank
3. Go to the Setup Tab
4. On WAN Connection Type make sure it is set to "Obtain an IP Automatically"
5. Go to the DHCP tab and make sure it is enabled
6. Unplug the Roadrunner modem and the Linksys Router.
7. Wait around 15-30 seconds
8. Plug the Roadrunner modem in and wait until all the lights except the ethernet/computer connection are on.
9. When they are all on plug the Linksys router power back in
10. Wait around 30 seconds and see if your getting a connection
Otherwise get back to me. Good luck.
Jan 30, 2009 | Linksys Wireless-G Broadband Router
Problem with network
Make sure the physical connections are correct. Modem connected to the Internet Port of the router and your PC to port number 1 on the Linksys router as well. Try to reset the router. Hold the reset button at the back of the router for about 20 seconds. After that, unplug the power to the router and to the cable modem. Wait for 30 seconds. Plug the modem first, wait for the lights to stop blinking then plug in the router. Check if the internet works fine again.
Sep 06, 2008 | Linksys Computers & Internet
Linksys Wireless-G WRT54GS Router (e125894) Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
