Question about Microwave Ovens
How do I open the Braun KSM 11 coffee grinder so I can replace the power cord?
  • elite14 Sep 28, 2010
    I think that may work for one of the later grinders. The KSM 11 has a slotted screw head in the center of the bottom part which is part of the main motor shaft through the machine. Undoing that screw releases the blades, but does not separate the top and bottom sections. A picture of my machine can be found athttp://www.flickr.com/photos/seezunge50/...
    The top (silver) and bottom (black) sections do not seem to want to separate. Any ideas?
    Thanks
  • Anonymous Mar 14, 2014
    How do I open the Braun KSM1R coffee grinder because I want to change the cable
    President:
  • 2,777 Answers
May I ask why you want to replace the power cord? Is it frayed / damaged? If so then just cut it off and attach a new extension to the cord, avoiding opening up the machine. You can get a new end for the cord, or cut the cord short and essentially get a new cord without opening up the machine. Check with a local hardware store for power cord replacements and they will show you all the options. Otherwise let me know why you feel you need to change the cord.
Thanks
Tim
Posted on Sep 29, 2010
    President:
  • 1,961 Answers
These are the steps to get access inside.
1. There is a single philip screw on the receptacle end of the bottom plate...unscrew it.
2. On the other end .. it is held by a plastic tab... push the bottom plate slightly backward.
3. When the bottom plate comes out a little... slid it on the direction of the power cord to get it out of the way.
4. From that opening, it would be enough for you to start in replacing that power cord
Alp
Posted on Sep 28, 2010
  • wrihar Jan 24, 2011
    I have had to replace the cord a couple times on mine over the 15 or 20 years I have had it.
    the cord becomes intermittant where it exits the case.
    I also have replaced the brushes and the safety switch post.
    There is no better grinder than the KSM 11.
    This is how to open it.
    1) Use a flat screwdriver to unscrew the shaft that holds the blade. It is under the label on the bottom. remove the blade.
    2) The placstic piece under the blade has 2 flats.... use a open end wrench or good plyers and turn the plastic piece 1/4 turn counter clockwise. This is a 1/4 turn lock.
    3) pull the top and bottom sections apart.
    4) remove the black disk that hides the motor.
    5) remove the motor by compressing 2 sides opposite the cross piece that holds the top of the motor. This is sorta like opening a bottle of mouthwash where you squeeze the sides to unscrew the lid.
    Good Luck.
My coffee maker wont turn on
Many coffee makers use neon bulbs to indicate that power is on. These do burn out after a while, but replacement is usually somewhat difficult. In this case, the coffee maker still works; you just don't have the immediate visual indication.
Many of the urn-type coffee pots have problems with the power cord breaking where it goes into the pot. To fix this, you need to remove the bottom, cut the cord where it is broken (on the outside of the pot), strip it back to match the part of the cord remaining inside the pot and crimp on new terminals of the same kind used on the original ends. The hardest part is squeezing the strain relief clamp where the cord enters the pot to remove it, and putting it back on. Study it carefully as it you remove it from the cord so you know how it works. To avoid a repeat of the same problem (and buying a new cord), be careful not twist the cord or bend it too tightly at the strain relief. NOTE: one of the wires in the power cord has a rib on the outer jacket. This is the neutral wire. Make sure it connects to the same place inside the pot as the original neutral.
Other failure points are at the power switch, or (rarely) the heater element. I've seen a programmable coffee maker with a burned-out relay (magnetic switch in a black plastic box on the circuit board). The clock and timer worked, but the heater wasn't getting any power. That part is about $5.
The easiest way to identify the problem is with an ohmmeter. Start by removing the bottom of the coffee maker (unplug it first!). Identify the heater terminals (the heater looks like a small version of the one in your oven and has either screw or slip-on terminals). Connect one of the ohmmeter test leads to each heater terminal to measure the heater resistance (typically 5 - 20 Ohms). If you have a basic (non-programmable) coffee maker, turn on the power switch and measure the resistance from each terminal to each prong on the plug. You should read either nearly zero ohms, or the heater resistance plus not more than a few tenths of an ohm. If you read open to one prong of the plug, you are on the track. Trace where the wire from that heater terminal goes. If it goes to the power switch, check the resistance of the power switch in the on position. If the reading is more than a couple of tenths of an ohm, the switch has dirty contacts, or it's broken or burned out. If you have a good connection from the heater to the power line side of the switch, but you get open from there to the hot side of the plug, the power cord is bad. Likewise, if you get an open reading from the other heater terminal to the neutral side of the plug, the cord is bad.
Programmable coffee makers have a similar troubleshooting procedure, except that you have to check for live AC voltage with the pot plugged in - this is not something to try if you aren't trained in the safe way to do this.
Sep 09, 2011 | Microwave Ovens
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Sep 06, 2011 | Microwave Ovens
I need a new lid for my Russell Hobbs 9702 Coffee Grinder but the item is no longer available and I can't find spares. The little plastic tab on the lid has broken off, this tab makes the grinder work...
fold a piece of paper or thin card board and put it in the hole the tab went in and you can have your coffee until you can find a replacement on ebay or amazon.
May 20, 2011 | Russell Hobbs Microwave Ovens
After grinding coffee,can you submerse in water to clean
No!!! You can clean the cup that the coffee goes into, but do not get the grinder in the water...
heatman101
Nov 25, 2010 | Microwave Ovens
I have an electric fry pan purchased in 1977 (no kidding) manufactured by Nesco for The Hoover Company. The NESCO model is BC01 and the removable electric cord with temperature control on it, model jpr...
Take a look at the picture on this web link of the 3 power cords.
(scroll down just a little)
http://www.toastercentral.com/cords.htm
The pin spacing sizes are 1/2", 11/16", and 1 & 1/16ths inch.
Then you can go to this page:
http://electrical.hardwarestore.com/12-33-appliance-replacement-cords.aspx
scrolling down the same distance and look at the details of each cord.
Most large hardware stores have these cords if you know the Woods Industries number. Usually 0288, 0290, 0291, 0293 There are a few others but they are all in the same range from 0288 - 0293 (WOODS INDUSTRIES)
If you can not find it at a hardware any appliance parts center will also have them. Just remember the WOODS INDUSTRIES numbers.
Kelly
Sep 08, 2010 | Microwave Ovens
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
NO POWER
1 the obvious question.... have you tried a known working outlet. 2. Most likely the internal fuse has failed and must be replaced. You can access this fuse by removing 4 side panel screws, (2 on each side) and 6 rear chassis cover screws. BEFORE you start unplug the unit. Remove the 10 screws. Standing behind the unit, then lift the top cover slightly and pull toward you. the side guide tabs wil unlock and the cover will come free. Once the chassis open aviod the large capacitor as it can still ruin your day. Follow the power cord until you see the fuse block. Remove the fuse... obtain an EQUAL value replacement and install the new fuse. reinstall the cover making sure the side guide tabs interlock on the front sides of the chassis. Plug the unit in and see if you have any signs of power.... I.e light on with door open or control panel dispaly lights up. If you have visible signs of power places a coffee cup filled with water inside the microwave and see it it heats up. If it starts and then all the power goes off again you probably have a bad diode. If it works fine then your in luck.
Jan 06, 2010 | Sharp Microwave Ovens
It suddenly will not turn on. The breaker is ok. It is an M-170, about 11 years old.
Have you tried it in a different power outlet?
Or just try some thing else like a lamp or a toaster in that power outlet.
Have a look around the where the power cord goes in. Is there a fuse or something like that you can see?
Apart from that my advice for Microwave Ovens is "No User Serviceable Parts Inside" If you open it up and don't put it back together correctly you can cause yourself serious injury or death. Microwave repair people have a tool to check for microwave leaks after they put it back together. If you got 11 years out of it you have done OK
Treat yourself to a new one. :)
Aug 15, 2009 | Microwave Ovens
Microwave Ovens Logo
215 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
