Question about Baumatic B180 Electric Single Oven
How to remove elemnt - Baumatic B180 Electric Single Oven
  • Baumatic Master
  • 3,463 Answers
Remove cover at rear of oven compartment, there you will see the element., remove securing screw/s, and replace element.
Posted on Sep 28, 2010
Lower oven bake element not working
go to sears and take the serial numbers off your appliance and they will get you a new element for it and you can take the old one out and the new one in. Ask them at sears how to do it and they will tell you.
Dec 11, 2011 | Ovens
I have a bosch double oven and the main oven fan element has failed. Do I have to remove th eoven to get access to replace it
It should not be neccessary to remove from cabinet.
Remove cover at rear of oven and you should be able to change the elemnt from inside.
Feb 10, 2011 | Bosch HBN 43R550B Electric Single Oven
The oven i have is actuly a AKZ446IX but looks the same as the AKZ159,the problem is the oven part does not come on,the grill above it thats ok,so i need to fix the oven. ...
If it is a fan assisted oven and the fan is working o/k, then you need to replace the oven elemnt, located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2010 | Whirlpool AKZ159IX Oven
Wont heat up but fan seems to make noise that its working
If the fan is working o/k, then it is safe to say that the oven elemnt is faulty, and needs to be replaced.
This should be located at the rear of the oven compartment behind a removeable cover.
Nov 19, 2010 | Ovens
How to fit new grill elemnt to stove type 720EF?
You have to remove the complete oven from the kitchen cupboard and then take the top and back off to give access to the wiring.
All the information is in the handbook, if you want a copy, then supply an email address, so that I can register it on my shared folder of the BT Digital Vault you for to take a copy.
Jun 28, 2010 | Stoves 720EF Electric Double Oven
Frigidaire glass top range
yes u can.unplug the unit from power.remove the screws under neath the glass top at the from and lift the top up,hold it up using a piece of stick like u hold bonnet of car.then u can see all the elemnt and they are pretty straigtfoward to chg.
Aug 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My hot light stays on and every thing is cool to touch
yes , hopefully you have a seperate indicator light for each of the elemnts, makes it easier to see which has gone bad, but if yo know which burner you were usins at time of incident then you can assume that it was that elemnet. replacement of the elemnt is required, for a it has a short in the theremistor, not a hazard, more of an inconvience, so i would have it taken careof but no need to rush its not an emergency, its only an faulty indicator, the elmnt is not actually heating
Mar 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Explanation of terms.
corrrect, electric OUTAGE, is a "power cut"or "failure"and a Broil element, is the elemnt located on the top of the inner cavity of your oven, bake elemnt is lower and broil is upper
Jan 04, 2009 | Whirlpool RBS305PDS Electric Single Oven
Fire Mondel # PLEB30T9FC
very possible hat the element is no good, does it look physically burned???? if so replacing the elemnt is the only option,2 screws and 2 wiredis all, simple to replace, unplug/disconnect power first,,, the wires are always live to the elemnt!!!!!!!
Dec 21, 2008 | Frigidaire GLEB30T8A Electric Double Oven
We need to install the lower heating element in the upper oven
ill aasumme that yo can see the elemnet in question, and its not a "hidden bake" elemnet located under the oven floor.. should be an easyrepair, with a little bit of patience. don trush shoudl only take 10 min anyway. TURN OFF POWER> LIVE WIRES TO ELEMENT AT ALL TIMES. REGARDLESS OF UNIT ON OR NOT!!! ther ewill be 2 screws along the bottom of the element holding the elemnt in the unit. after emoving carfully slide the old elemnt out a few inches, slowly pull out, for the wires are still attached to the back of elemnt and you want them to stay there you dont want them to disconnect and fall behind unit, (you will then need to remove the unit form the wall to access htem). so pull slowly espescially if you feel resistance in the wiring. after you getit out far enough simply unplug and plug in the new one reinstalll and you shoud be fine
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Baumatic B180 Electric Single Oven Logo
87 people viewed this question
Top Baumatic Ovens Experts
ashburton
Dennis Boxerman
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
