Question about Electrolux EWDW6505GW Builtin Dishwasher
My dishwasher is diplaying "loc" meaning the controls have been locked. i have tried holding the unlock button but it hasnt worked. any suggestions?
4 Suggested Answers
allbrands
  • 600 Answers
SOURCE: My dishwasher has locked all of the control
Hello, Thank You for using FixYa. I will be helping you today.Try holding it longer and if that dont work you might have a bad touch membrane.
Thank You and please rate my answer if it was helpful..
Posted on Jun 22, 2011
daddysmurf18
  • 6 Answers
SOURCE: my dishwasher is displaying the "loc" how do I unlock
Try turning the power off at the circuit breaker ,wait for awhile then turn it back on
Posted on Nov 06, 2012
InMrFixIt
  • 121 Answers
SOURCE: My dishwasher DU1050 is stuck on Lock and I've
Hi! cccole
Dishwasher may be in bind. remove kick plate and make sure adjusters are not putting case in a twist, or pressing unit to tight to top of cabinets.
InMrFixIt.
Posted on Jun 19, 2011
What does a LOC code mean?
loc has to do with control lock:
control lock (press and hold)
to lock the controls between or during cycles, press and hold the add steam button for 5 seconds. loc will be displayed if you attempt to wake up a "between cycle" locked unite and loc will alternate with cycle time remaining in a "during cycle" locked unit. repeat to unlock the controls when you are ready to operate the washer. use this feature to reduce the likelihood of accidental operation by children.
Sep 03, 2015 | Kenmore Dryers
I have a code of loc coming on and my dryer wont work how can I fix this issue??
The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
My fridgidaire affinity dryer has loc error and will not let me start it
The control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the "LOC" on the display is cleared. Locking the control is done the same way it is unlocked.
Mar 04, 2011 | Dryers
Push any button and 'loc' flashes seems to be locked out
Press Options and Select at the same time and hold for 10 seconds or until "LOC" is no longer displayed to unlock the controls. Press and hold the same buttons for 10 seconds until "LOC" is displayed alternately with the estimated cycle time to lock the controls. Unplug the machine for at least half an hour, if pressing the buttons does unlock the controls, to forcibly reset the machine control and eliminate the possibility of an electronic glitch.
Oct 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
Loc
It means the control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the “LOC” on the display is cleared. Locking the control is done the same way it is unlocked.
Sep 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Loc code
the control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
Oct 23, 2009 | Frigidaire ATF6000ES Front Load Washer
What does LOC mean, that's what the screen displays along with err, when I try to press start or cancel.
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 17, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
MY WASHING MACHINE THEY DONT START WHEN I PUSH START IT SHOW UP THE WORDS ERR AND LOC
Jul 02, 2009 | Kenmore Washing Machines
Kenmore 417.44092500 front load window shows Err then flashes LOC and the minutes for the particular load setting. Door doesn't lock. Tried to get into diag code setting on spin/drain and pushing pause &...
Mar 08, 2009 | Washing Machines
Electrolux EWDW6505GW Builtin Dishwasher Logo
1,322 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
