Question about Audiovox NVX226 GPS Receiver
Audiovox GPS failed to open file ctype.dat exiting application
  • gem24w Jul 23, 2008
    I remove the cd card. I have hit the reset button. There is nothing is else to do. This is a brand new Gps. I used it once.
I had the same problem and the only way to fix it is see if it is still under warranty and send it back to the company.
Posted on Sep 26, 2008
I have not solved it but why is finding the answer so complicate......password, username and then after that a $9.00 why can't you get a simple answer
Posted on May 27, 2008
We have bought a new GPS and we would like to delete the address that we have installed. We will be giveing our old GPS to someone. Thank you.
Glad to help you!
Connect your device to your computer and from your computer enter in the root of the device and check for a file called
user.dat
or
favorites.dat
Delete that file and you're done!
GOOD LUCK!
Apr 01, 2011 | Garmin StreetPilot C330 GPS Receiver
Tip
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will...
In the next few posts i will post some tricks to make your phone faster and also recover precious RAM.
1. MOVE HELP FILES TO MEMORY CARD
If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card.
Enable CAPS OFF
open Xplore or fxplorer and move C/resource/help to E/resource/help.
All the apps will find it automatically in the E drive.
This trick will increase your phone memory thereby making your phone a little bit faster.
2. DISABLE LIFEBLOG PERMANENTLY
first use jbak taskman to kill lifeblogobserver process
make sure x-plorer is set to show hidden files
then go to c/data/lifeblog/database
now delete the lifeblog.dbfile
reboot phone
now use jbak taskman to kill lifeblogobserverprocess once again!
select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM.
if you want to use lifeblog again go toc/data/lifeblog/database
and untick hidden and read-only
3. STOP AUTO STARTUP OF APPS ( for a faster boot up)
You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process.
The info of all the start up apps is stored in c:\private\100059c9\start.dat
whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating.
When ever you again want to enable the startup apps just remove the .txt extension.
You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it.
The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want.
You can even further boost up your phone start up by renaming files like
C:\private\100012a5\DBS_101F99FB_NSmlDSSettings.db
C:\private\100012a5\DBS_101F99FB_nsmlagentlog.db
C:\private\100012a5\DBS_101F99FB_NSmlDMsettings.db
C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b
C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat
C:\private\101F99FD\nsmladapterlog???.dat
C:\private\101f9a06\nsmldmtree.db
C:\private\100056cf\clockapp.dat
C:\private\100059a8\nitz.dat
C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db
C:\private\100012A5\101f8683_ScShortcutEngine.db
C:\private\1000850\logo*.*
C:\private\100012a5\DBS_10205030_accpolicydb.db
C:\private\1000c959\localdata\commondata.D???
C:\private\1000c959\localdata\localdata.D???
To .txt files or simply delete them.
Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
on May 09, 2010 | Cell Phones
No maps found
When your tom tom comes up with the no maps found error message. There are several causes to the problem.
If you updated your map using the latest map guarantee and then get the error No maps found, make sure you install the latest version of the TomTom application.
Check for the latest application: Connect your navigation device or memory card to your computer and click Update my device in TomTom HOME to check if a new application is available.
You can check the version of your application in TomTom HOME. Connect your device and then click Manage my device and select the Items on my device tab. Expand Applications and then click More info.
Your map may require the latest version of the TomTom application.
Check for the latest application Connect your navigation device or memory card to your computer and click Update my device in TomTom HOME to check if a new application is available.
HOME may not immediately offer the latest application version when installing a downloadable map on a blank memory card. Re-connect your memory card to HOME and check for the latest application by clicking Update my device in HOME. HOME this time offers the latest application for your device. Try Installing maps on a new memory card
You need to also make sure all files are in the right places. Browse the content of your navigation device:
Windows XP: Click Start > My Computer and then double-click the removable drive of your device.
Windows 7 / Windows Vista: Click the Windows start button > Computer and then double-click the removable drive of your device.
Mac OS X: Double-click the desktop icon of your navigation device.
Check the following:
The map folder (e.g. Western_Europe) needs to be located in the root directory of your navigation device or memory card. This means the map folder may not be inside another folder. Before you move the map folder we recommend that you create a manual backup.
The map folder needs to contain at least the following files
cline.dat cname.dat cnode.dat faces.dat mapinfo.dat poi.dat tables.dat tmccodes.dat traffic.dat .meta (map v705 or higher will have/need this file) .meta.dct (map v705 or higher will have/need this file) .pna
If any of these files are missing restore a previously made backup or re-install your map to your device (in TomTom HOME click Add Traffic, Voices, Safety Cameras etc. > Items on my computer).
Hpe this was helpful. Thanks for using fixya.
Jan 26, 2011 | Tomtom ONE GPS Receiver
Error message,failed to open file:igo/480_272/loading.bmp exiting application. clarion map 670 sat nav,seems to be in constant loop trying to pair phone on bluetooth and above error appears when selecting...
The solution that worked for me is: in your iGO installation folder, open SYS.TXT file then find section [interface] next check if exist something like this: skin="ui_igo8" if not then add it, but you must first check in your DATA.ZIP file what is the name of the folder it can be ui_igo8_da, ui_igo8_pda... depending on version. After that iGO will load normally. One more thing, I've added this section at the end of SYS.TXT file [loading] show_statustext=1 show_progressbar=0 progressbar_x=62 progressbar_y=174 progressbar_bmp="loading_progressbar.bmp" ;you can disable this line bu putting ; sign at the beggining loading_bmp="loading.bmp" ;you can disable this line bu putting ; sign at the beggining
Hoppe this will help you!
Aug 04, 2010 | GPS
I have windows 7 software on a dell computer. Have not been able to open email attachements with extension of DAT or \r\nCOMX. any suggestions?
You should have a software application to read that kind of file in order to read what's really inside on the said file or to view his original image. but you can actually grab and launch it to gnome player or what types of player you have as long as the program inside of it is according to the specified extension file name because for your information DAT stands for Digital Audio Tape or Digital Tape Recorder. NOTE! don't try VLC because it didn't support DAT files.
May 18, 2010 | Dell Computers & Internet
Mavis Beacon 20 moving a user file
First add yourself (or have an admin add you) as a user on the 2nd computer.
Login into your account and start Mavis Beacon.
Create a name and do an activity or two.
Exit Mavis Beacon and open your My Computer icon
Navigate to the following folder:
C:\Documents and Settings\YourUserName\Application Data\Broderbund\Mavis\
Now delete the existing prefs.dat file and copy your prefs.dat file into the "Mavis" folder.
Restart Mavis Beacon and you're ready to go.
Mar 22, 2010 | Encore Mavis Beacon Teaches Typing Deluxe...
Change address numbers to higher numbers
open the file that says cline.dat or something like that with notepad/wordpad and find the street you're looking for and change it form 000-1999 to whatever you want
May 03, 2009 | Cobra Nav One 3000 GPS In Car Navigation...
AUDIOVOX NVX226 NOT RUNNING APPLICATIONS
the file is missing contact the nanufacture
Apr 11, 2009 | Audiovox NVX226 GPS Receiver
Tomtom go 520 speech recognition not working
Create a text file called support_asr.dat, open that file and write the number 1 in the file. Save and close then copy the support_asr.dat file to the ASR directory on your TomTom internal drive. You must have map version that support ASR.
Jul 04, 2008 | GPS
Fatal error, unable to open application database
Have you tried the reset button? It would be found on the lower right side on the rear panel. Don't really know if this will fix your particular problem, but it might be worth a shot.
Dec 13, 2007 | Audiovox NVX226 GPS Receiver
Audiovox NVX226 GPS Receiver Logo
197 people viewed this question
Top Audiovox GPS Experts
spyderdog8
Level 1 Expert
Are you an Audiovox GPS Expert? Answer questions, earn points and help others
