Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Left cd door not ejecting when push
My left cd door quit opening all of a sudden on my cdmix2
    Genius:
  • 1,550 Answers
Maybe the motor charge belt are in bad conditions and need a replacement or the cd sistem are out of time.Good luck
Posted on Jun 02, 2008
How can I eject a cd drive from an Acer Aspire e 15?
Are you asking about ejecting the drive or the CD in the drive? The drive you may or may not be able to eject. Flip over the laptop look for slides or what looks like switches under the CD. Some units may have these releases. You usually slide them to one side or another and the drive can be removed.
If you are asking about the CD, i.e.the laptop wont power up but you still have a CD/DVD in the drive you want. Usually there is a tiny hole on the drive door. It's about the same size as a paperclip diameter. Unbend the paperclip until you have about 1 inch of wire straight out at a 90 degree angle from the clip. Gently slide the wire into the hole on the drive door and give it a gentle push. The door should unlock and come open just a bit allowing you to pull the door all the way open and remove your captured CD. The gears that open and close CD's are plastic and can be stripped very easy so be gentle. Close the CD by slowly pushing the door closed.
Dec 31, 2014 | Acer Aspire Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My numark cdmix2 doors dont open
Both doors? When you press switch (eject) does display change? I doubt you have 2 defective eject switches. Its more likely you need to replace both CD drives, this is quite common.
Apr 06, 2010 | Nu Mark Numark Cd-Mix-2 Dual CD...
Cd player in ford expedition quit showing CD
If you can not eject cartridge
Press and HOLD eject button insert credit card or similar under cartridge.Push firmly in and move left to right untill it ejects,this will locate micro switch.
The fuse is located on the back of the stacker,this is ok because your head unit recognizes stacker.
Nov 14, 2009 | 2003 Ford Expedition
DVD drawn bides and won't open when the eject button is pushed.
open "my computer" ...in the left panel click on the "eject the disc"
Mar 20, 2009 | Sony Computers & Internet
Can't get the disc out...
is the light flashing on the drive ? .... be that as it may you will note a small hole on the face of it.... put a small round object in there and push... that should open the door.
Mar 08, 2009 | LG GCE 8523BB (GCE-8523BB-10PK) CD-RW...
LG car CD, MP3, WMA Receiver wont play or eject CD's??
please observe when you push the eject button display applys the open or eject cd?.if yes something wrong with your mechanisum.it has several microswitches and bad contact of them occur this type problem.sometime loading mechanisum stuck because of loose belts.open the cover of your cd player and check cairfully.
come back with results.
nuwan
Jan 08, 2009 | Car Audio & Video
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Cdr tray/door won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Aug 09, 2007 | Philips CDR785 3-Disc CD Recorder
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
122 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
