Question about Toto Neorest 600 1pc. Toilet MS99OCGR-01
After the flush and it fills up the water overflow keeps running
    Problem Solver:
  • 6 Answers
Check the over flow valve shutoff and make sure it is at the right height
Posted on Sep 28, 2010
Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
Troubleshoot Your Toilet Without a Plumber
www.popularmechanics.com/home/how-to/a4117/4303948/
Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
Emergencies - Overflowing toilets - Toiletology 101
www.toiletology.com/emergenc.shtml
You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
Nov 19, 2015 | Town Home
How do you stop a power flush toilet from constantly running?
You'll have to see if the water is leaking past the flush stopper or into the overflow tube. The tube is the little pipe where water drains if the tank is filled too high. The flush stopper is a rubber flapper mounted on the bottom of the overflow tube. If water is running into the tube, then the flush valve may be stuck, so shake it up and down (gently) and hopefully it will be freed. If water is not running into the tube, then reach down and try to seat the flapper stopper to see if something was lodged there to keep it from seating all the way. Would be a simple fix either way.
Dec 08, 2014 | Home
Toilet keeps running even after new flush valve and new fill valve
If the level is set correctly it may be the overflow tube. If it is cracked or has a hole in it water can leak through. Hope this helps.
Dec 18, 2013 | Home
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
I just got a new Kohler toilet from HD. After installed it, it keeps running water fro every 10 minutes.
the water level could be adjusted too high and it is running down the overflow tube. if the fill valve makes a noise trying to fill every 10 minutes then you have a flapper on the flush mechanism that is not sealing properly. it may be out of shape or have something stuck under it.
Dec 29, 2010 | Kohler - Toilet - Two-piece - Highline -...
I have a Duravit Starck 2 toilet cistern which is approximately 5 yrs old, recently water from the cistern runs constantly into the bowl. I have renewed the flush value without any success. I would...
Did you replace the flush valve or the flapper?
There must either be a problem with the seal between the two surfaces of the flapper and flush valve or the flapper is being prevented by the flush system to returning to make a seal against the flush valve after the water completes draining during the flush cycle or more likely water is draining through the overflow tube.
Make sure the sealing surfaces are clean and not damaged.
Make sure the flapper is not being interfered with and is able to return to the closed position to make a complete seal against the flush valve.
Check adjustment of the water fill level to make sure the water is not filling above the water overflow. If the inlet valve does not shut-off when the level is adjusted to the proper level the water inlet valve may need replacing.
The following videos may prove helpful.
Dec 22, 2010 | Home
The water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
Sep 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
I need to flush the water from my radiator out and fill it in with new water and intercooler. but i dont know how to flush it out, need some help please
The way that I flushed mine out was to remove the upper radiator hose at the radiator and kept pouring water in the radiator until I could see clear water coming out of the detached hose. Keep an eye on the open end of the radiator because once it is filled with water, it will overflow out of the open end. Also, be careful of the water coming out of the detached hose, it will be very hot.
Jul 20, 2008 | 1996 Mazda 626
Toto Neorest 600 1pc. Toilet  MS99OCGR-01 Logo
131 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
