Question about Honeywell Programmable Thermostat Heater
I have purschased a HoneyWell non-programmable digital thermostat (focusPro5000) th5110d1006. It requires 6 wires. rc - r - y - c - w - g - I have central A/C heat pump electrical. 1 heat 1 cold & I think 1 transformer outside. The thermostat that I am replacing is a Janitol hpt-18-60. It has 7 wires. Mercury Label color of wire y yellow g green r red o orange w2 white e black c blue The thermostat works well, but I'm told focuspro5000 digital is better. I don't know how to match the 7 existing wires with the new Honewell thermostat. Rc & R has a factory installed jumper. Would you match the existing wires of the old thermostat with the new HoneyWell? Thanks in advance for your support. I do not wish to make a mistake here, could be costly. V/R, Raymond O. Webb Email: Raymond.Webb@mchsi.com
  • raymond_webb Sep 28, 2010
    I have 7 wires; places for 6 on the honeywell. the slot for rc is not on the janitol. I don't know what corresponds to that. The Janitol has w2 and e slots that do not correspond to the honeywell. So, I'm lost here on the rc w2 e. What wires go with these? Thanks again for your help? I do not have the info I need to proceed.
    I have laid out the 7 slots color of wires and labels for the janitol. I have laid out the labels for the honeywell, but do not know which color wires go into rc on the honeywell or where the w2 and e wires go from the janitol into the honeywll.
    Raymond
    President:
  • 2,777 Answers
Yes, the wiring should be the same for both thermostats. If you want, you can consult HoneyWell directly to confirm, but I am quite sure this is the case. It wouldn't hurt to confirm with HoneyWell, but you should be safe to proceed, their number is 1-800-328-5111 if you want to check.
Thanks
Tim
Posted on Sep 28, 2010
  • Tim Grayson
    Tim Grayson Sep 28, 2010
    Yikes, that is a nasty one indeed, hmmm did you try contacting honeywell? They are much more versed with exactly what needs to go where. Without seeing it in person I am afraid to say for sure, I know what you are saying but am unsure which goes where. Let me know, it will be much easier for you to explain it in person...
    Tim
SOURCE:
I took my Honeywell focuspro 5000 non programmable thermostat off the wall to change the batteries and I put new batteries in it and back on the wall and now my air conditioner wont come on do you kno
I can only suggest that you check and make sure all of the pins are straight and not bent over from trying to align the back plate with the back of the thermostat. Ive done it and its easy to do if you are not very carefull.
Sep 19, 2014 | Honeywell TH5110D1006 Focus PRO 5000...
I have a honeywell non prog thermostat and dont know how to change the redaing from fareheit to celsiuc focuspro5000 thanks phil
in your manal it shows what to do .if no mamal call honeywell and they will walk you through it or go on line honeywell ,com
Jun 12, 2010 | Honeywell Programmable Thermostat Heater
I have a new honeywell thermosat rth2310 and the heat will not go on
Did you just install it????? If not check the batteries and replace them first....check for corroding also....if you just replaced the thermostat did you wire it correctly????/Wire for Wire???? If so if you have 4 wires in your thermostat you require a jumper wire between RH & RC....if you have 5 wires...no jumper is required....is the Furnace power on???
Nov 01, 2009 | Honeywell Programmable Thermostat Heater
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
"Cool On" indicator on for the first time- system not cooling
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH5110D1006
Click on the Link Above. At the bottom of the page is the Downloadable "Instruction Manual" for your Thermostat.
Hope i Helped
Please Rate Me
George
Apr 30, 2009 | Heating & Cooling
Non programmable Honeywell to programmable
the 230 doesnt sound compatable with your system. you are gonna need a t stat that is compatable with Heat Pumps.
Mar 18, 2009 | Honeywell Programmable Thermostat Heater
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
216 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
