Question about Epson Stylus CX5000 InkJet Photo Printer
Need the printer driver to use printer on a different computer
  • 779 Answers
Bought a used HP1022n printer. Need to hook up to my computer as a local printer. When trying to instal the driver, the set-up says waiting to connect to the computer. I have the USB cable connected,...
Make sure you don't have the printer connected until after you install the driver. If you had the printer hooked up to the computer before you installed the driver, uninstall and start over. There should be a prompt during the installation process that tells you when to hook up the printer. If that doesn't work, you may have a driver for a different operating system than what you have on your computer. If you need further assistance, please email me the operating system you are using on your computer.
Feb 07, 2011 | HP LaserJet 1022n Printer
Tried different ports, different usb cables. No luck. It shows in the devices but will not print
Check for the printer requirement for operating system and maybe it is not compatible.
Correct Printer icon name. Correct usb port driver needed. Check your device manager for usb port driver if properly installed. otherwise use LPT port if there is install driver for your computer.
Dec 16, 2010 | Office Equipment & Supplies
I got a printer software cd epson 760 for my printer is this right cd am using
hello there
these are two different printers you stated ..one is Epson and the other is Lexmark -- two different makers
if you have the Lexmark printer , go to the link below and download the drivers onto your computer. make sure your printer ius disconnected from the computer.
open the file you downloaded and install the drivers, but when you select the drivers from this link, make sure its fr the correct operating system you use (WWinodws XP, Vista). After installing the drivers, and all software is in your computer (drivers), then attache the printer with cable to the computer . The computer will tell you it found new hardware and it will recxognise the printer.
http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X5470&focusedTab=DOWNLOADS#1
if this helped, please rate me
Nov 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have an older printer on my new computer that wont download why
Every hardware has different drivers for different versions of operating system, so in the same way, you also need to install a newer or different driver for the new computer. If you can let me know which operating system is installed on your new computer, and what make or what model is your printer, I can help you find the driver for your printer. I hope you understand what operating system means, i.e. Microsoft Windows xp or Windows Vista or Windows 7 or OSX etc...etc..
Let me know so that I can help you further.
Good luck.
Thanks for using FixYa.
Sep 15, 2010 | HP Office Equipment & Supplies
When I print to different printers, the spacing does not look the same as it does on the computer screen. It is different on different printers.
Your printers are either set up differently - make sure their settings are identical!
or the drivers are not sending the same information... if you can use Postscript drivers then do so - that will solve the driver problem.
Otherwise, it is necessary for you to create templates for the different printers so that the output is consistent regardless of which printer you are sending to.
Oct 05, 2009 | Computers & Internet
Where to download drivers for the apple cinema 30inch display
The drivers are included in Leopard.
If the display is not working please ensure the video card you are using is compatible with the 30" display.
Jan 14, 2009 | Apple Cinema HD 30" LCD Monitor
My Officejet 5610xi All-in-One will not print from my computer. The printer tells me it is not connected to my computer
try to check the cable or the usb connection from the computer to the printer it must be loosing or not connected properly to the interface. Install the the driver camed with your printer to your computer to be able to use it.
CHARCOIS
Oct 17, 2008 | HP Office Equipment & Supplies
Error message from printer properties : Can not print test page. This operation can not be completed. Take note that printer self-test is working and from printing option cleaning cartrige work perfectly....
You need first to do the following:
Check first a different usb cable ( be the case).
Check that the printer is the default printer or you are not printing to a different printer installed in windows
Do driver setup procedure.
Disconnect printer from usb.
Go to 'installed printers' and remove the printer from windows (right click and delete). If you have documents in printer cue you may need to purge documents in cue.
Restart computer (printer disconnected).
Re-install drivers from disk (printer disconnected).
Only connect printer to usb when required by printer install software or after installing software.
If the above did not work the printer can be faulty, in this case usually it shows some dignostic message, like flashing red light etc.
Check also that is not a windows problem, by installing in on a different computer (get a laptop) and printing a test page.
Regards
Apr 15, 2008 | Office Equipment & Supplies
Sofeware for canon muliPASS MP390
Here you can download drivers and software for mp390. Just select drivers and download tab, and select your OS (eg.Windows xp, Windows Vista etc.).
regards
Mar 22, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Epson Stylus  CX5000 InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
