Question about Salton Microwave Ovens
I pruchased a Salton portable cooking range Model HP-10C. It is not functioning properly. Are there any autherized repair shop in Edmonton, Alberta. Thanks.
2 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave runs for 3 seconds and shuts off
This is an inverter-driven model, and this is one way the inverter fails. Often it will tick, too, but the cooling fan may be too loud to hear ticking. If you haven't had smoke, then it may not yet catastrophic. I would bet that a thorough resoldering would take care of it. A good technician can troubleshoot and repair this, as needed, but often they will just replace the inverter. Sometimes that's actually cheaper. Troubleshooting an inverter is way too much for someone without good solid technical experience. I would call a shop and ask for an estimate to replace the inverter. Good luck.
Posted on Oct 14, 2006
Set the power level on a Salton microwave,counter-top style?
If its coming on when to switch it on he problem can be the pc board but if does not come on at all yo need to check yo fuses
Sep 16, 2014 | Salton Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
I have a Salton micorwave oven (MW-2027P). The timer works but the cook setting will not start. There is also no light on the inside when I open the door.
I had this exact same problem with my salton microwave! Even tried taking it back to the store, but with no reciept there was little they could do. Anyways try jiggling the clasps on the side of the the door, the ones that connect it to the microwave. Mind you don't jiggle too hard. Now firmly close the door, you should hear a distinct click. Now try it! The light only works when the microwave is on. The microwave won't work unless the door is closed properly and my problem was the claps were stuck! I hope this helps.
May 15, 2011 | Salton RRMW1 / RRMW1A 900 Watts Microwave...
I have a GE Profile Spacemaker model JVM1660SB005, maufactured in November 2000. I attempted to change a burned out bulb on the left side. I did not check the manual to see how to remove the bulb, nor...
I regularly see (and repair) this light and / or fan failure on model JVM1660SB005 and most any model of over the range microwave.
The problem is on the controller assembly, which I regularly repair very affordably.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 05, 2017 | GE Microwave Ovens
Mar 05, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable stopped working. Food doesn't cook properly.
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $35 to $45. The coupler is less than $10. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Jul 24, 2010 | Microwave Ovens
It has power but is not heating anything
In order for a microwave oven to cook foods, its "engine" - the magnetron - must also be functioning. If the keypads, turntable, lights and all other functions are working but the food is not cooking, the magnetron has failed. Some local repair shops can provide a reasonable cost to replace, and it comes down to how old the oven is and is it worth repair or replacment.
Feb 15, 2010 | Microwave Ovens
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
Oct 13, 2006 | Panasonic NN-S252WF Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Salton Microwave Ovens Experts
William Miller
William Miller
Joseph Hoffmann
Are you a Salton Microwave Oven Expert? Answer questions, earn points and help others
