Question about Dynex 5-in-1 USB 2.0 Mini Memory Card Reader
The Cd is too small for my MAC
The CD containing the driver for the MAC is too small for my MAC and it may get stuck. Is there a website where I can get a download of the MAC driver? Dynex doesn't have it on their site. Thanks.
  • 2 more comments
  • Anonymous May 31, 2008
    I am also having the same problem.  I have an iMac and the CD that came with the 5-in-1 is too small.  I have been searching for an online download for the driver but I am unable to locate it.
    Does anyone have an idea of how to get the driver installed the computer?
  • Anonymous Aug 13, 2008
    same problem.  The online solution at dynex doesn't seem to properly download to mac either.
    Same here.  And the driver offered online at Dynex doesn't seem to properly download to mac either.
  • heyy77 Sep 03, 2008
    It's simply to small, i already inserted it and had to take it to the mac store to get it out! and If so many people have this problem there should be a solution in the handbook. How else can I upload the photos
IT WILL STILL WORK!
Yeah, if you just plug it into the computer and insert a card, the drive pops up on your screen. The CD is not required (thank God) and it WILL GET STUCK, so don't try to insert it. (I did...took me 15 minutes and some very small tweezers to get the stupid thing out!)
Posted on Mar 30, 2009
Man am I glad I read this posting. My DX-CR6N 1-6 memory card reader/writer was not being recognized by my MacBook, like the Quick Setup guide said it would. But, I was scared to put the small CD into my MacBook drive, so I my hubby took the disk on his PC and saved all the info to a disk, so I could put into my drive. BUT there were no drivers for the Mac so it didn't help! Well, that's not completely true. I was able to access the User Manual that had more information on trouble shooting, so here's what it says, maybe one of these will help you.
"If memory cards do not appear in My computer or no icon appears on the desktop when a card is inserted into the reader (Mac OS), check the following:
  • Make sure that the USB cable is fully connected to your card reader. Unplug and reconnect your card reader.
  • Try a different memory card of the same type in the same slot. If a different memory card works, the original memory card should be replaced.
  • Disconnect the cable from your card reader and shine a flashlight into the empty card slots. Look to see if any pin inside is bent, and straighten pins with the tip of a small, pointed instrument, such as a mechanical pencil or jeweler's screwdriver. Replace your memory card reader if a pin has bent so much that it touches another pin.
If memory cards appear in My Computer (Windows OS) or Macintosh (Mac OS) but errors occur when writing or reading, check the following:
  • Make sure that the memory card is fully inserted into the slot.
  • Some cards have a read/write security switch. Make sure that the security switch is set to Write Enabled (or unlock) --this one solved my problem.
  • Make sure that the amount of data you attempted to store has not exceeded the capacity of the card.
If no icon appears when a card is inserted into the reader (Mac operating systems), check the following:
  • The card may have been formattedin Windows FAT 32 format. Using a PC or digital device, reformat the card using the OS-X compatiable FAT or FAT 16 formats."
I hope this helps you!
Posted on Sep 12, 2009
I'm using Leopard and just hooked it up, put in the memory card & it worked.  I also was uncomfortable inserting that little cd into the Imac and couldn't find the darn drivers.  Thanks a lot, Dynex!
Posted on Jun 22, 2008
Posted on Jun 17, 2008
It will work!
Place the mini sd card into an sd adapter. Then it will recognize it.
kitty
Posted on May 03, 2009
  • 88 Answers
This device is plug and play, the software allows you to edit the appearance of the cards icon in the file browser window (whichever one you happen to be using)
Posted on Jun 15, 2011
The device works on an older MAC operating system as well.  Definitely don't insert the disc.
Posted on Sep 03, 2008
How to remove a stuck CD from a old mac
HI THERE IS NORMALLY A VERY SMALL HOLE NEXT TO THE DRIVE,THAT A PAPER CLIP CAN ACCESS. PUSH IT IN UNTIL THE CD POPS OUT.
Sep 09, 2014 | Apple G4 Computers & Internet
Cd stuck inside dvd on macbook
find a small hole beside your cd and stick a needle into it.
Apr 19, 2012 | Apple MacBook Mac Notebook
Asus p4ge-mx motherboard driver cd please need help
You can download the contents of the CD from ASUS's website.
  1. Go here: http://support.asus.com/download/download.aspx?SLanguage=en-us
  2. Input p4ge-mx in the search box on the left.
  3. Select p4ge-mx from the search results.
  4. Select your operating system
  5. This should be a list of all the up-to-date software and manuals related to your motherboard.
Good luck, I hope this helps.
Mar 01, 2011 | Computers & Internet
I have HP ScanJet 5370C and I want to install it, in my computer mac OX
You will have to order this CD-ROm containing the drivers and software from HP. MAC OSX drivers are not available for download from the website.
Click here to order the CD
Nov 04, 2010 | HP ScanJet 5370C Flatbed Scanner
I have an SVP XTHINN-8061, but the CD is Cracked. The unit is new, but the CD was damaged in the mail. Is the CD actually needed or is there a download that is necessary, since the CD is broken? ...
the cd contains drivers for the cable to connect to pc, it also contains so software for viewing or editing photos, u can download the cable driver from the company website
Sep 17, 2010 | SVP Xthinn 8061 Digital Camera
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
I have lab top and a cd is stuck in it sounds like it wants to come out but nothing Can someone help
There will be a small hole in the CD tray, straighten a paperclip and push in to release tray
Sep 01, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Cd stuck in drive
you can eject manually. There's a very small hole on the front of your CD drive. Get something like a needle. put the needle inside that hole and push. Your CD should pop out.
Mar 24, 2009 | Apple iBook G4 Mac Notebook
Can not use the cd - rom. It does not open automatically.
Hi arganamj,
I assume you are using an IBM based PC, not a mac (in other words any computer not a mac). If that is so, then your CD-ROM drive has a mechanical release, not electrical.
Simple way to determine if your CD-ROM is stuck is to insert a punch into the release hole next to the normal eject button on the CD-ROM's front faceplate. It is a small hole about 2 millimeters wide, and if you bend a paper-clip into a straight line it is very easy to press the spring-release mechanism and eject your CD.
If this does not work, then your device is clearly jammed or defective, and would need to be repaired or replaced.
If this does work, inspect the CD tray and make sure there is not a CD stuck inside of the drive. After you have done all of this, and the drive is still having problems ejecting from the machine, it's time to look at your drivers and make sure your computer is talking to your CD-ROM properly and knows how to use it.
You might have to download new drivers from your manufacturer's website in order to repair a broken or missing driver on your machine. I would suggest not attempting re-installation of drivers yourself unless you feel capable of removing windows operating system components.
If you still would like to try that if you are willing to re-install your drivers through trial and error, post again and we can walk you through some of the process of driver installation. Hope that helps.
May 02, 2008 | Computers & Internet
Dynex 5-in-1 USB 2.0 Mini Memory Card Reader Logo
1,872 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
