Question about Dacor DCM24SS Convection Microwave Oven
Everything works but microwave makes louder noise than usual and does not cook/heat.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If it's a loud hum/buzz sound then 90% it's usually a bad magnetron and other times it's a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
Why does my kenmore microwave have power in but does not work?
Really need more information - what do you mean it "does not work"? Do you have any lights or display showing? Does it run and make sounds like it's working but it just isn't heating? Or is it completely dead? Each symptom indicates a different problem.
If it's completely dead, then it's either a fuse or a TCO (Thermal CutOff device - a thermal fuse, usually located above the cooking cavity).
If you've got a display, but it doesn't "run" when you press Start, then it is probably a door interlock switch.
And if it runs and makes noise (especially if the noise is louder than normal), then it is probably the magnetron tube.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 30, 2014 | Kenmore Microwave Ovens
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Everything appears to be working with our microwave except it is not heating or cooking. All other functions appear to be o.k. I am not 100% sure of the model number and I'm not at my house to get that...
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("runs but no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
Nov 22, 2009 | Goldstar MV-1615 Microwave Oven
GE Microwave Model # JE1860: Unit does not heat. The timer counts down, but the oven does not heat.
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Nov 27, 2008 | Microwave Ovens
The microwave facility in this multi function Sanyo shower wave oven EM-D993 has ceased to work. Everything else does.
When you hit Start to cook, do the inside light and turntable come on?
Nov 24, 2008 | Sanyo Microwave Ovens
Troubleshooting my Kenmore 721.66227
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Otherwise, when you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting Sears to get it fixed free.
Aug 21, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Everything works but no heating?
With inside light and turntable on, louder sound, and no heat, this is usually a shorted high voltage rectifier diode or a bad magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 14, 2008 | Jenn-Air JMV8196 Microwave Oven
My microwave is not heating up suddenly...its working fine till morning...suddenly it stopped heaing things....[lease suggest me with a solution
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 09, 2008 | Microwave Ovens
Won't heat
Aug 01, 2008 | Maytag MMV5207A Microwave Oven
Microwave Ovens Logo
99 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
