Question about Kenmore Refrigerators
Freezer is working fine, Fridge side is cool but not cold. could it be the fan is not working? where is it and how hard is it to change?
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 28, 2010
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
I have a 5 yr old side by side fridge. just a couple of days ago I noticed that temp. in the fridge was way too warm. Freezer is fine, but when I felt for any kind of cool air circulating into the fridge...
frost on the coils means the compressor is working and it is making "cold" if the cold isn't getting to the fridge side the fan the brings the cold air to the fridge side is ethier blocked off or not working. If you have a small thermomator use it to check the fridge side apx 38 to 40 degrees is the "food zone". the fan is usually not to expensive and often not that hard to change. there is a timer that defrosts the coils usually about once every 24 You may see a small knob on the defrost timer. watch its position over several hours and you should see it move position. if it doesn't move then the defrost timer is faulty. the most expensive part of the system is the compressor and it sounds like that part of your system still functions. If the freezer is getting plenty cold but the fridge part is not cooling off you have an air flow problem. It is not uncommon for these fans to make noise and then fail altogether.
Apr 21, 2011 | KitchenAid KSCS25FKSS Side by Side...
My freezer works fine but refridgerator is wont get very cold
If freezer is frosting up, check fan. if fan is not working in fridge the freezer will ice up and the fridge will not get cool air.
Feb 09, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
GE side by side fridge/freezer. Fan in fridge is not spinning.
Replace that fan that blows the cold air into the refrigiator.
Jan 06, 2009 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
