Question about John Deere A,b,g Tractor Carburetor Float Dltx10
John deere b backfires when trying to start wont run unless you pull start but then runs fine
  • 45 Answers
The old J.D. tractors, like your "B" model have a compression
release valve on the side of the block. You are to open this valve when starting, once started you close this valve.
These tractors have (2) very large cylinders that create a great deal
of compression this is the reason for the release valve.
This is why it was back firing during starting, also draining the battery.
Posted on Nov 26, 2014
    Scholar:
  • 150 Answers
The starter is drawing to much current on start. Check battery and starter.
Posted on Sep 28, 2010
TRY TO START BUT BACKFIRE THRU CARB AND WONT START AT ALL
roger, try a new spark plug, i just fixed a John Deere that took two days only to find out that the new plug out of the box was a bad plug. also check the fly wheel key , it may have sheered off.
Sep 24, 2015 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
John deere tractor wont take up throttle
try some lucas gas treatment. may have something to do with the float in carb. Might replace it and try.
Jun 20, 2013 | Garden
84 john deere 410b stalls out
could be something floating around but did you fuel it one day and not the other try and run it with the gas cap off there is a vent on the cap that gets plugged
May 13, 2012 | John Deere Garden
My lt150 lawn tractor is backfiring when the pto is engaged and cuts off in about a min of use, but it runs fine without the pto on.We have drained the gas and put in new gas, and cleaned out the...
Sounds like the float is bad - what happens is the float sits just a little off and when you add the demand of more fuel it skewers the RPM by starving the engine.
Try removing the carburator and either adjusting the float by bending the tab or replace it. As part of this repair i suggest you just replace the needle and seat as well if they are over a year old.
Thanks,
Gary @ Fix Ya
Jul 22, 2010 | John Deere Garden
John deere 425 lawn tractor. it wont start but it has spark and fuel the starter engages and the fly wheel turns
If your tractor has an anti back fire solenoid in the front of the carburetor then it should start if you remove it and cap it off with a pipe plug.It should run if the solenoid is the problem,if so you really should replace it but if it is'nt prone to backfiring with it remove you don't have to.You may also have a bad seat switch,confirm this by jumping the plug with a piece of wire to temporarily test it.
Jan 14, 2010 | John Deere 420,1020,2010,2020,2510,2520...
BACKFIRES THROUGH CARB,WONT START ,MOTOR IS KAWASAKI FC420V IN A JOHN DEERE LAWN TRACTOR
Most likely water in the fuel. Drain the tank and clean the carb. replace with fresh gas. Mr fix it is a dumby
Apr 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere A,b,g Tractor Carburetor Float Dltx10 Logo
621 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
