Question about Linksys WRT160N Wireless Router
Ireless-B 2.4GHz Broadband ROUTER Linksys i need key
  • 779 Answers
The key maybe written on the bottom of the unit otherwise you will need to loginto the router and goto the wireless section to find the key and security type
Connect with a cable to your computer, and enter the Router's default IP address, 192.168.1.1, in the Address field. Then, press Enter. A login screen will appear. (Non-Windows XP users will see a similar screen.) Leave the User name field blank. use the default password admin. Click OK to continue.
Posted on Sep 28, 2010
Lost my wep address for the linksys g broadband..how do i retrieve it?
you may either use programs that can help scan your registry for iy, or reset the router to the default settings and set a new WEP key
Jan 30, 2011 | Linksys Wireless-G Broadband Router
I had a working system. After bying a new laptop Linksys asked for a key. I forgot the key. What tot do
Hello
You need to reset the router using reset button at back of the router and do the configuration again.
Hope this helps, good luck.
Jan 03, 2011 | Linksys Wireless-G Broadband Router
Pin number
you can get the pin number by contacting the provider.
Jun 30, 2010 | Linksys Wireless-G Broadband Router
I can't find my WPA key and its not on the back of my router i have a Cisco linksys help
you need to log in the router config and access the key.Check its manual for more info.
Mar 14, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
Can i connect a cricket broadband to linksys router
Not directly, you need to connect a Modem, to the actual Broadband connection, and connect that to the "Router" then you connect, through, the Router, out through the Modem to the broadband connection.
Mar 05, 2010 | Linksys Wireless-G Broadband Router
How would i find my security key for my linksys router?
Log into the router's web from a computer wired to the router (default address is 192.168.1.1)... the default password is (no user name) admin. Go to the wireless security page and you'll see the keys listed there. If the password has been changed, you'll need the password to avoid resetting the router.
Feb 03, 2010 | Linksys Wireless-G Broadband Router
I tried to secure my Linksys Wireless-G Broadband Router last night and set it up to require a password by going to 192.168.1.1. I also did something(I can't remember what) on the linksys website that made...
When configure security, is better to connect to network cable. Because once u setup the wireless key such as WEP or WPA, u will be log out from the wireless connection and u need the correct key to login.
Feb 26, 2009 | Linksys Wireless-G Broadband Router
How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Nov 07, 2008 | Linksys Wireless-G WRT54G Router
Router works with wire not wireless
there are lots of thing ht can be done like enviroment chek
wep key config ,firewall setting, go one by one minimize the firewall then try to ping it
to to network connection set it up again
this time with proper wep key and in enviroment make sure ur router is not near a carpet or microwave or any plant
May 22, 2008 | Linksys Wireless-G Broadband Router
Where do i find the network key?
You can find the network key (wep key) on the web interface of your Linksys router (192.168.1.1), under the Wireless tab, look on Wireless Security.
Nov 28, 2007 | Linksys Wireless-G Broadband Router
Linksys WRT160N Wireless Router  Logo
21 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
