Question about QSC MX1500A 2-Channel Amplifier
Hello I have a Peavey CS 800 and a QSC 1450. They are overloading at the imput and generating low power to the speakers. What could cause this. I have checked the cables and the mixer is the same one I have run just this past weekend. Its a mackie 1604. I have switched out the mains and sends and still get the same result.
  • Scott Frye
    Scott Frye Oct 05, 2010
    Are the 2 amps linked together?
2 Suggested Answers
  • 4234 Answers
SOURCE: CS-800 buzz in channel a
First a couple of questions:
1) Is the level of buzz controlled by the volume control? Based upon your initial post I would think yes.
2)When you say you want to use the other amp as a regular amp, do you mean to drive a single speaker or more?
Dan
Posted on Feb 07, 2009
How do i set the switches on a qsc rmx 1450 power amplifier
All off, except The "Clip Limiter" Those should be on for your speaker protection.
Sep 14, 2013 | Audio Players & Recorders
I want to no wat this parts number is Q4025p for a peavey cs 800
2 Channel Peavey CS-800 Amp (800 Watts) ... Peavey CS-800x 800 Watt PA Stereo power Amplifier. The Part in question Q4025P is an alternistor. Two SCRs back to back that may have shorted out if it is not working.
Apr 11, 2012 | Peavey Audio Players & Recorders
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
Peavey cs-800 amplifier
Believe it or not, these amps have been around since the early 80s and are still available today. Contact a local Peavey dealer or Peavety directly,. These parts are still available.
Dan
Aug 25, 2009 | Peavey Audio Players & Recorders
Caused speakers to smoke:(
If it's the speaker cabinet itself that';s smoking, you have most likely burnt some components in the passive crossover. Pull it out and you may see melted parts or scorching on the circuit board. Peavy does repairs on it's own products pretty reasonably if there's no local tech. Call Peavey Customer Srervice at 877-732-8391.
Apr 30, 2009 | Audio Players & Recorders
Dan
Feb 06, 2009 | QSC MX1500A 2-Channel Amplifier
Peavey CS-800 PA power amp 1 channel is out
Hi Bill,
It's a log time ago that I repaired those amps., but I give it a shot.
There's a speakerprotection after the finals, what I remember it's a triac (SAC187, or something like that).
You will find it at a small pcb at the back of the amp. Normally it has three legs but the centre is cut away. If it's down you will measure 0 Ohm at the output, also with a switched off amp.
Thats all I can remember, it was about 25 years ago.
Maybe it helps,
Gerard
Jan 25, 2009 | QSC MX1500A 2-Channel Amplifier
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
65 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
