Question about Nintendo Wii Console
My wii will not play any of my games it keeps saying unable to read the disc can you help.
  • 16 Answers
SOURCE: unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Posted on Oct 04, 2007
SOURCE: wii cant read the disc
try putting the disks in a adiifernt position untill the wii eads it well
Posted on Aug 27, 2008
frankgant
  • 250 Answers
SOURCE: Wii unable to read disc
One of two things has probably happened and is the case 9 out of 10 times. Your drive may have gone bad either due to a chip failure or a laser failure. It's also possible if the unit has gotten hot that the connection to the drive isn't making good connection anymore. This happens a lot. To fix it you would have to open the unit up. I don't recommend this if you have never worked on consoles or other electronics before. If the unit is under warrenty send it in for repair. Otherwise you would have to pay for the repairs. You can also sell the unit as broken on ebay and generally recover quite a lot of your money.
If you are good with repairs of electronics you may choose to open it up and do some troubleshooting. There are several places on the internet that outline how to open the wii and how to troubleshoot it's problems. If you decide to go this route you will void any warrenty you might have. However sometimes this is about the only solution people have without spending money for Nintendo to fix it.
Posted on Sep 12, 2008
  • 15 Answers
SOURCE: "Unable to read disc" Wii
Your Wii most likely has a problem with the system that reads the disks. If you system is under warranty, you should be able to get it replaced or fixed at no charge, since it is Nintendo's problem.
Posted on Dec 04, 2008
  • 33 Answers
SOURCE: Wii "unable to read disc"
If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Feb 26, 2009
Unable to read disc
I'm sorry you're experiencing this. This means your system's laser is weak and will need to be replaced. You can open your WII system and clean the laser with a cotton swab (only a drop of rubbing alcohol) and this may help it just a little, But a replacement would be best.
Mar 31, 2010 | Nintendo Wii Console
Unable to read disc message on Wii
Try a cleaning disc. this may fix this issue. if the issue remains, it will confirm a major problem within the optical assembly. you will need to replace the optical assembly in this case. it has failed.
Contact Nintendo for the optical replacement procedure.
Jul 26, 2009 | Nintendo Wii Console
Wii unable to read gamecube disc... :(
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Mar 23, 2009 | Nintendo Wii Console
Wii will not play any of my games discs
Made a video showing how I fixed this exact problem on a Wii.
Mar 20, 2009 | Nintendo Wii Console
Unable to read disk
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
139
Dec 16, 2008 | Nintendo Wii Console
Dec 04, 2008 | Nintendo Wii Console
Unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Nov 10, 2008 | Nintendo Wii Console
Nintendo wii
does it play the other games? have you exchanged the game for a new one? your laser might be getting weak or is dirty,
Apr 24, 2008 | Video Game Consoles & Games
Wont read discs
If it only does this for this one game, you may have a defective game disc, it happens. Often, if you have just recently purchased it, you can return it to the store and tell them that it was defective and get a new one. If not, you can always try cleaning it though I doubt that's the problem.
nintendo.com says "If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options."
Oct 01, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
