Question about Rowenta Steam Generator DG050 Iron
I have algae build-up in the water reservoir of my Rowenta steam generator. How do I clan it? I always use spring water. Never distilled water.
DiYerTech
  • 70 Answers
SOURCE: no steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Posted on Feb 02, 2008
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
  • 336 Answers
SOURCE: is the rowenta iron supposed to have distilled
tap
cheers!
Posted on Jul 11, 2009
aferrell09
  • 105 Answers
SOURCE: I have a Rowenta steam iron and it has been
the loss of steam is from usually from a barrier or o-ring or some sort of insulating material it has to be sealed because if it is not the the steam will not build up the pressure required for adequate cleaning power, try to seal up where the water is coming from, and yes you should be able to use something to get rid of the build up just make sure you rinse it all out so it wont mess anythng up and tap water is fine you will just get that build up from it cause of the chlorine and other products in tap hope this was helpful:)
Posted on Nov 16, 2009
heatman101
  • 43501 Answers
SOURCE: ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
I want use distilled water in my new Rowenta DG8030 steam station but instructions say to use 1/2 tap water and 1/2 distilled water or 100% spring water. Why can't I use 100% distilled water? Why can't I...
Believe it or not, distilled water is quite corrosive, more so when hot. Distilled water doesn't contain any dissolved ions but the water is ionic in nature, the ions of every water molecule tend to dissolve away other elements. Steam generating plants and steam ships as well as steam heating systems treat the water with chemicals to keep the water from eating away the metals of the system and test the chemical makeup several times a day while operating. [I spent 4 years in the Navy on a steam powered ship.]
The same holds true for smaller steam appliances like espresso machines and steamers. A very thin coating of calcium carbonate [limestone] is a good protector but too much makes for inefficiencies and burned up elements.
Somewhere I read that Chrystal Geyser spring water is approximately the correct ion balance for espresso machines and I have been using it for years in my espresso machine. In any case you still need to occasionally de-scale your steamer per the manufacturers recommendations.
Feb 03, 2015 | Rowenta Irons
How do I get the boiler on my rowenta steam generator to fill? I was given this model.
You should only use distiller water in the steamer. Never ever use tap water! This is what caused lime and scale build up.
Since it's to late, you have nothing to loose by trying this to descale the unit:
Put up to one cup of white vinegar into the reservoir. Fill 3/4 of the way with water. Turn unit on and let it heat up, but DO NOT RUN STEAM THROUGH THE LINE. Once heated up, turn unit off and let it set for hours. Drain and rinse well. Then run a water only batch through the steam cycle. There are companies that sell special de scaling solutions. But hopefully, the vinegar will work.
Apr 25, 2014 | Rowenta Steam Generator DG050 Iron
Mineral buildup in my steamer
To eliminate mineral deposits and prevent corrosion on your steam iron, give it an occasional cleaning by filling the reservoir with undiluted white vinegar. Place the iron in an upright position, switch on the steam setting, and let the vinegar steam through it for 5-10 minutes. Then refill the chamber with clean water and repeat. Finally, give the water chamber a good rinsing with cold, clean water.
-From Reader's Digest 150+ Household Uses for Vinegar
Jul 16, 2012 | Rowenta Irons
Do I use distilled water for steam in my iron?
Always use distilled H2O to avoid build up of calcium/lime deposits. That's for ANY iron.
Jul 18, 2011 | Rowenta DX6700 Iron
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
Cleaning a Rowenta steam iron
According to the manual, you should use regular tap water as long as it is not above 12 grains of hardness. Never use 100% pure distilled water, Rowenta recommends using inexpensive bottled spring water.
Jul 18, 2010 | Rowenta Effective DX1900 Iron with Auto...
My rowenta professional iron drips, how can I fix it?
Are you using distilled water to refill your iron? Distilled water can cause drips if used all the time. Refill with tap water and see if the drips stop.
Jun 22, 2009 | Rowenta Steam Generator DG050 Iron
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
May 14, 2009 | Rowenta Commercial Garment Steamer - White
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta Steam Generator DG050 Iron Logo
192 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
