Question about Dishwashers
Miele excella series G 2670 SC technical fault #69 --- what is this fault?
  • 1 more comment
  • Anonymous Jul 26, 2008
    have new excella G 2670 and after 4 months of great service it has come up with Technical Fault F68.
  • Anonymous Dec 25, 2008
    After 6 months or so the same error code Fault 69. What is it?
  • forestroad Dec 25, 2008
    I have the same problem on the same model, Fault #69
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
I have a Miele 2670 dishwasher with an error code of F69---what is that and how do I fix?
F69 is a Plint float switch, usually placed in the bottom of the machine.
Oct 13, 2014 | Miele G2670SCSF Dishwasher
Miele G 694 SC Plus Dishwashers : Cannot exit Test Program
Ok,if you unplug it,it should reset it.
Mar 09, 2014 | Dishwashers
I have a miele excella series g2670sc that says "no water intake". We cleaned the filters (not dirty) but it still says the same thing. We live outside the parameters of normal travel for the...
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is betting to the valve, the timer might ba faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
Feb 22, 2011 | Miele G2670SCSF Dishwasher
Miele g 892 sc intake/drain light is lite and unit will not operate
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Apr 25, 2010 | Miele G892SC SS Dishwasher
'Close the Door' on Miele WT 2670
Door lock faulty or wires to lock adrift.
Mar 06, 2010 | Miele WT945 Front Load Washer / Dryer
WHAT IS F11 ERROR MIELE DISHASHER G 1232 SC
hi
this is a drain fault. you will probably find the drain spigot under the sink is blocked where the drain hose connects.
Dec 13, 2009 | Miele G892SC SS Dishwasher
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Miele Dishwasher G 2630 SCi fails to fill.
Debris is jammed in the valve for water ejection. It's jammed slightly open. This happened to me and it was a very small piece of plastic from the lip of a tupperware bowl.
Oct 04, 2017 | Miele 24 in. Incognito G843SCVi Built-In...
Dishwashers Logo
543 people viewed this question
Top Dishwashers Experts
