PAPER JAMS IMMEDIATELY AS IT FEEDS IN. NO ERROR MESSAGE, JUST AN ALARM TELLING ME IM OUT OF PAPER & NEED TO RELOAD. I'VE CLEANED IT OUT W/ COMPRESSED AIR REPEATEDLY. THERE APPEARS TO BE A SMALL COPPER-LOOKING PIN DOWN IN THE FEED ROLLERS THAT MAY BE THE CULPRIT, BUT I DONT EVEN KNOW IF ITS PART OF THE PRINTER ( A GUIDE -WIRE? ONLY ON ONE SIDE? CANT FIND ANY SPECS THAT'LL EVEN TELL ME IF I SHOULD TRY TO REMOVE IT.
  • will_power3 Sep 28, 2010
    ITS A CANON MX320 SERIES. ITS TOO DIFFICULT TO REACH BY HAND, BUT I HAVE USED A PAIR OF NEEDLE-PLIERS TO ATTEMPT A "GENTLE DISLODGE" -- NO LUCK. HOW CAN I FIND OUT WHAT IT IS
    President:
  • 3,278 Answers
Hello.
I know you are looking for an answer to the "wire" question, but I wanted to provide some info from Canon regarding paper jams.
http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/PIXMA_MX320.aspx?faqtcmuri=tcm:13-643852&page=1&type=faq
Hope this helps.
Posted on Sep 28, 2010
    President:
  • 1,566 Answers
Hello there,
Can you tell me the model of your printer? Have you tried pulling it gently and see if it is fitted well there to be considered a part of the printer?
Errors with my Printer/scaner
Jessica:
This could be one of a few things... First, Windows 8 is a completely different animal from Windows XP! Try reloading your printer driver in Windows 8. If this doesn\'t work, you need to clean the paper pickup rollers at the front of the printer (where the paper first feeds into the machine. I use a Q-tip moistened (not sopping wet) with rubbing alcohol... gently scrub the whole pickup roller and then the feed roller next to it. Check carefully (with a flashlight) for any shards of paper that might be blocking the paper path. There is also a sensor flag (small finger of plastic) sticking up that the paper must hit to let the printer know that the paper is feeding through. If you do not see the sensor flag, it is either jammed or has been broken off when a piece of paper was pulled backward out of the paper feed area. First reload the printer driver, and try to print. If it doesn\'t print, check and clean the rollers and look for the sensor flag.
May 31, 2014 | HP 1050 Plain Paper Inkjet Fax
Turn on machine & alarm immediately comes on. Flashing check printer 6000.
Are the cartridges in working order. I had similar problem with another make of printer when printer lights kept flashing and one of the cartridges was defective.
Feb 26, 2014 | Canon PIXMA MP170 All-In-One InkJet...
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Lexmark 7675 paper jam
> feeds unevenly
Usually, there are two, maybe three, rollers that should _evenly_ pull the paper through the path.
Check that each roller is making good contact with the paper.
> out of paper error-message
There's a small sensor, and usually a "finger" that rises when the weight of the paper is not sufficient to hold the finger down. Check for "dust" clogging/blocking this finger.
If all else fails, it's time to take the printer to a qualified technician, for a professional cleaning & tune-up.
Apr 16, 2010 | Office Equipment & Supplies
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Check Printer and Press resume key message along with Alarm light
Too many things can cause that, paper jams, carriage errors, printhead problems, purge assembly errors, feed roller errors, need more info to be of any help.
Aug 12, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
182 people viewed this question
k24674
jasbo
jasbo
