We needed new batteries so we replaced them in the clock first and then in the outdoor box several times and the clock won't come back on.
    President:
  • 4,070 Answers
Hi! Please do remove the battery again then see how it goes. The system may need to relearn itself after the battery replacement.
Posted on Sep 28, 2010
Medion md41199 atomic clock, cannot get the outdoor temp to show, how to fix please
Remove ALL batteries in transmitter AND clock.
Insert new batteries in outdoor transmitter.
Insert new batteries in the (receiver) clock.
Wait until outdoor temperature is received AND displayed on clock BEFORE setting time/date/etc.
Mar 11, 2013 | Audio Players & Recorders
What battery do I need to replace and how do I replace it?
the clock battery in the watch and unscrew the bottom piece and then put a new battery in where the old one was then screw the bnottom back on and well la go as new
Jul 07, 2011 | Sportline 345 Electronic Pedometer
I have a 4003 osz time clock and it does not turn lights on and off. Where can I get new insides for the same box.
As of November 2010 or before, Paragon is no longer making timers or parts except Defrost timers.
4003 0SZ is not a defrost timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
0SZ suffix appears to be 120Volt astronomic time clock that turns ON at Dusk and OFF at Dawn
4003 is DPST 120Volt 40 amp mechanical timer
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Tork shows 120volt mechanical Astronomic time piece
7200Z DPST
http://waterheatertimer.org/pdf/7000Z-series-wiring.pdf
http://waterheatertimer.org/Tork-timers-and-manuals.html
MR Supply sells 7200
Intermatic mechanical astronomic clocks:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/astronomic.aspx
These time clocks are Indoor-outdoor and can control 3 different 120V Loads, for example store light in front, outdoor light in back, and outdoor sign. All Loads turn on-off at same time.
Beverly Hills shows the V4547r
Intermatic also makes electronic astronomic time pieces where voltage is selectable, with many timing options (programming is detailed and complicated):
http://www.intermatic.com/products/timers/electronic%20time%20switches/astronomic%20electronic.aspx
NEMA1 is indoor box
NEMA 3R is indoor-outdoor box.
SPST means timer can control 1 Load
SPDT can control 2 120V Loads
1000 Bubs sells the ET8115C
Add a comment for more free help, for example a question about a specific model or about cross-over wiring. I have experience with wiring diagrams and experience with some different models.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 11, 2011 | Paragon Vintage 24 Hour Timer Command 12...
How do I get the outdoor temperature to work on my Sharp Atomic clock, have replaced batteries in both clock and transmitter and reset numerous times
Hello jdb..... The outdoor transmitter needs to undergo a wee bit of maintenance. Remove those new batteries and clean the battery contacts with the eraser on the end of a common pencil. Then replace the batteries. IF you notice that the batteries slide in easily, use a small flat blade screwdriver to gently lift the battery contacts to increase the contact when you do slide the new batteries in. Joe
Thanks for choosing Fixya!
Dec 19, 2010 | Baby Gear
My outdoor temp will not work
if you've already cleaned the contacts and replaced the battery, your transmitter unit needs to be replaced. You can purchase a new one through the link below. If your clock's model number isn't listed, use the "Contact us" link at the top of the page.
Bill B
Apr 25, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
Nov 19, 2008 | SkyScan 86742 Digital Atomic Wall Clock
3m precision clock lost instructions
HOLD SET BUTTON UNTIL ITEM YOU WANT TO CHANGE FLASHES. USE + AND - BUTTONS TO CHANGE ITEM . PUSH SET TILL IT RUNS ON.
Oct 25, 2008 | SkyScan 86742 Digital Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
27 people viewed this question
jasbo
jasbo
