Question about Creative Labs WebCam Live!
It was working but last week sudenly not working
Can' get my e mail.
  1. Enter your full name, date of birth and the last four digits of your Social Security number. ...
  2. On the next page, we'll show you a partially masked email address. ...
  3. If you recognize the email address, simply log into your account as usual.
  4. call toll-Free Number for more help 1-800-213-8289
1 800 213 8289 Epson printer technical support blog News For Printer Help
Nov 14, 2017 | Computers & Internet
Im having a lot of problems with a honda odyssey 2001. last month we took it to get fixed becouse the tcs light kept turning on and the gears didnt work properly,we got a new sensor called tcs and i guess...
Normally this problem is caused by a wheel speed sensor.Every wheel has a sensor to detect the mph of each wheel. the vehicle notices any major difference in wheel speed and makes the tcs light flash at you or stay on all the time.This is how the vehicle knows if your spinning or losing control of your vehicle.Have your mechanic verify that all the wheel speed sensors are working properly and have him check for diagnostic trouble codes in the computer. Hope this helps,
Ken
Oct 08, 2010 | 2001 Honda Odyssey
Hi i have got 1997 subaru Legacy, the internal air function was working fine, till last week, but sudenly, it stop working. I can see the display, but the air is not comming, not for the Aircond. and not...
Is this A/C or entire climate control problem? I have a 97, too, and took out my climate control unit and found debris and spilled liquid on the unit! Liquids play havoc on electrical connectors. Make sure all connectors are clean and thoroughly connected to housings. Check the harness for breaks in wiring. Could have a short someplace. Heat and/or too much current could possibly cause immediate stoppage. Never forget simplest method..... check the fuses both inside car and under hood. If it's A/C as the problem, check R134 level at certified mechanic. Don't run A/C with low coolant - could burn up compressor. Let me know how it goes!
Oct 04, 2010 | 1997 Subaru Legacy
All of a suden will not read DVD's "incorrect disk" We had a power outage last week, but that has happened before with no issues. Someone said the needle may be misalligned.
The processor in your player may have gotten scrambled from the power outage. Try pulling the AC plug and letting it stew in its own powerless juices overnight and then try it again. BTW, there is no 'needle' in any player; they use a tightly focused laser beam to read the disc.
Jan 03, 2010 | Sansui VRDVD4005 DVD Player/VCR
I am working with 2 Toshiba SX8 thermal printers. The text recently started shifting downwards for no aparent reason on both printers. Jobs that I have printed fine the last couple weeks have sudenly...
several reasons may cause this problem.
-On Tec printers, the height of the labels must be the most precise possible. You must include the gap height in the command
{D0350,1000,0320|} for la label size 100 mm and 32 mm high and 3 mm interval. If this information is missing, the printer may work correctly for some time and suddenly you'll have your phenomenon.
- You may have a label stuck under the sensor.
- You may need to recallibate your sensors.
- the correct sensor is not selected
Sep 21, 2009 | Toshiba TEC B-472 Thermal Label Printer
Headset mic not working
Sometimes this would happen to me and it was because i was too far away from the ps3 so the signal isnt as good, but if your up close like a foot away it will work fine. If that didn't work then you could pretty much use any kind of USB microphone and it will work.
Sep 30, 2008 | Video Game Consoles & Games
Downloading
Hi
I bought a arabic-English Dictionary NModel BAS-1875 two years ago. last week the arabic words become unclear in the dictionary...you just see black dots for the arabic letters while the english letters are still clear.
Thanks
Feb 28, 2008 | Office Equipment & Supplies
Creative Labs WebCam Live! Logo
13 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
