Question about Polaroid I533P Digital Camera
Lens on i533P broke
Lens is broke or jammed
how do i fix it?
what do i do?
Did you try to use brand new batteries and re-power on the camera?
Posted on May 26, 2008
When you turn on the power it stays on briefly and shuts off.i have already replaced the batteries
The camera is on an error as it shuts down, can be due to failure of the lens control system/main servo or control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of opening to check for any jammed mechanism. If this is hard for you, then it will be good to have it checked at a service for estimate as you do not have to run around for spares.
Dec 20, 2010 | Polaroid I533P Digital Camera
Lens stuck out, wont turn on
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Jan 03, 2009 | Polaroid I533P Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Auto focus
I would take the lens off and then put it back on, being careful to align the registration marks on the lens barrel and the camera.  It should click into place quite firmly.  If this does not fix the problem, take it back for repair.
Apr 29, 2008 | Nikon D80 Digital Camera with 18-135mm...
Canon A560
when it was dropped the gears in the lens assmbly were jammed if you can open the case to get to the assembly it's not to hard to fix you should see the gear that jammed and be able to fix it with a small screw driver
Apr 18, 2008 | Canon PowerShot A550 Digital Camera
Lens Wont Come Out & Beeps 3 times.?!?!
exact thing happened to me.
im guessing the lens is sticking out a little bit?
Try lining it back up.
Make the lens lined up.
or push the lens in lightly.
i did it and it worked for me.
Apr 01, 2008 | Polaroid I533P Digital Camera
Polaroid i733
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Mar 18, 2008 | Polaroid I533P Digital Camera
PINK POLAROID I733 CAMERA LENS
Good luck.
Mar 17, 2008 | Polaroid I533P Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Lens is broken
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Oct 03, 2007 | Polaroid I533P Digital Camera
Polaroid I533P Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
