Question about Maytag PYE2300AY Electric Dryer
Maytag mde9206ayw I tried turning on the dryer and it wouldn't start, pushed the button several times then noticed a burning smell - checked the breakers, they were fine any thoughts? Jim
  • 943 Answers
HI WHEN YOU PUSHED THE BUTTON TO START DID IT HUMM IF IT DID YOUR MOTOR IS THE PROBLEM ESPECIALLY THE BURNING SMELL
Posted on Sep 12, 2008
Hi. My Neptune dryer was not sounding as I remembered it. A higher pitch than usual while it was drying clothes. Then I noticed it was reluctant to start when pushing the "start" button, with...
burning smell is because the drum is not rolling and the motor is trying to turn, hopefully it did not damage the motor: more then likely it the drum rollers/glides, might want to check the idler arm here is a website that will help. depending on fast you need your dryer a good and cheap place to buy parts is on eBay, of course they can be purchased locally, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 10, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE9206AYW will not heat. What do I need
I assume it is a gas dryer. Turn it on and if no clicking sound is heard within 30 seconds the spark ignitor needs a replacement. If it is an electric dryer you need to check the relay for the burner system first
Apr 16, 2010 | Maytag MDE9206 Dryer
Maytag electric dryer. LDE9314ACE Drum won't turn, but sometimes will. Had friend turn drum manually while I pressed start/door buttons. Drum turned fine but when I let go of buttons to shut door, dryer...
The motor capacitor is burned. You can replace it yourself. It's on the motor. Take it down to a motor shop and they will have a new one. (electric motor repair shop)
Sep 25, 2009 | Dryers
Burning smell, Loud noise when start button and doesn't turn on
Belt, and skid plates very easy to change and not much money
Aug 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My dryer will not run, when I push the start
WITH YOUR DOOR OPEN ENGAGE THE DOOR SWITCH AND TRY TO START IT HAVE AN ASSISTANT START IT WHILE YOU HELP THE DRUM TURN. IF IT START TO TURN ON IT'S OWN THEN I WOULD SAY YOUR MOTOR MIGHT BE BAD OR TOO WEAK. IT MAY ALSO BE A BAD DOOR SWITCH
Apr 09, 2009 | Dryers
Electric Maytag dryer won't turn on after burning smell
LA 1053 Thermostat kit and the vent/ Lint collection probably clogged. When overheats its safety feature is to kick the thermostat offgetimage.ashx?imagetype=item&mfgname=maytag&brandname=maytag&idealitemnumber=la1053&standardimagesizecode=web_displayThermal fuse
Feb 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dyer MDE9206AYW
moter bad
start switch wont ingage
Jun 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag electric
Yes, I would replace the starter switch...Also, there is a relay next to the starter switch(behind panel) that may be on the blink.. Try switch first as they are cheap.. The Repay retails for around $50.00. Goodluck!
Dec 15, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
375 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
