Question about Sharp Televison & Video
The volume on our E67 series tv will not go past a certain level. how can i fix that?
  • Sharp Master
  • 736 Answers
It is true that you won't start to hear this television's volume increasing until the volume level passes 10. Then it gets louder until the volume level gets to 30 then between 30 and 60 it doesn't get any louder. This is the nature of this particular television. You can go into the audio category of the menu and increase the treble and the bass. Listen to the television with surround on and then off to see which one is louder. Connect the television to a sound bar.
After a television is a year or two old it may start to degrade naturally so you might benefit from being walked through an INIT. Call 877-332-7867 to be walked through one and the television may sound louder after it is complete.
Posted on Sep 28, 2010
Is there a way to set the volume so i dont have to keep changing them all the time
hello, are you referring to the volume of the TV set when you change channels? to reiterate every time you change channels the volume also changes? in this case I do not want to speak too much but I'm almost certain that television providers are required to adhere to a volume leveling standard which would require television broadcast stations to broadcast at a certain volume level for unity. Are you watching cable television? I happen to know that not all cable television providers level they're broadcasting some do.I notice that you are using a CRT unit are you attempting to use a converter box with the unit? If you are using a converter box there may be a chance that volume level is one of the options in the menu, I can not say there is much at all you can do about this.
As an alternative your television set maybe damage and the volume maybe adjusting randomly or in a way other than intended.
Good luck and thanks
Questions? Just ask!
Nov 25, 2015 | Televison & Video
Dualxdvd210 when volume is up it cuts out the bass. Can I stop this?
Most probably you need thicker wires for power supply to your amplifier.
Apr 10, 2014 | Dual Electronics Car Audio & Video
Volume is too low on shure 450 series II mic
Make certain you are connecting to a microphone level input.
Dec 31, 2012 | Shure 450 Series II Professional...
Wejust purchased a used Sharp CD-E67. It does not have an owner's manual. How do you open the disc changer?
two silver buttons down at bottom right under volume button the buton to the left rotates it and the other one on the right side close and opens it
Sep 18, 2011 | Sharp CD-E67 CD Shelf System
I have a Kenmore Elite Total Care System Top Load washer, and for the past two days, the water level will not fill past the medium level even if the setting is on Large level.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Apr 17, 2011 | Washing Machines
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
When i turn the volume up past a certain point the music stops playing and all i hear is a scratchy noise every couple seconds
This is usually due to the headphones or speakers not being able to play back the audio past that point, try a different set of headphones, the earbuds might be burnt out. some earbuds **** and cant play sounds past a certain dB the general dB levels tolerated without distortion are about 104-110 ish, but if you are listening anywhere near that your gonna hurt your ears. tests have shown that audio levels past about 90dB will seriously damage your ears after prolonged usage. Generally get nice in-ear ear buds with noise cancelation and never move your audio past 90% to clearly hear the music without damaging your ears.
I got my girlfriend some Jbuds J2 and they are great and i prefer them over my 200$ bose ear buds. check amazon they are about 14$ the J3's are around 24$
Nov 04, 2009 | SanDisk Audio Players & Recorders
What is the impedence/signal level at headphone jack?
A headphone jack is normally 16-32 ohms. If you are concerned that overdriving is taking place then turn down the volume level on the device. The connections should be ok. Just take some caution and keep you volume at around 50%-75%. You should be just fine.
B.S. Audio Engineering, Nick
Jan 22, 2009 | Sharp CD-E67 CD Shelf System
TV Volume settings
These are all settings that are put in by the factory and cannot be changed.
Nov 28, 2007 | Televison & Video
Volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Aug 25, 2007 | Toshiba 27DF46 27" TV
Televison & Video Logo
70 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
