Question about Pioneer TS-W3004SPL Premier 12" SPL Component Subwoofer with 3000 Watts Max. Power Car Speaker
I have a pioneer tsw3004spl sub and have tried running it at 2 ohms and it sounded worse than at 4 ohms. sounded less powerful if anything. the amplifier i have is a vibe blackbox 4 monoblock that has 1x450watts at 4ohm or 1x900watts at 2 ohm. how woud i wire the sub to run at 2 ohms as im guessing i messed up somewhere
sticky92505
  • 77 Answers
SOURCE: Wiring diagram for Pioneer TS-W3004SPL subwoofers
a good resource for wiring and information on the web can be found at 12volt.com
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: how do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Posted on Mar 10, 2009
etirbynnor
  • 655 Answers
SOURCE: How do i wire two 15 inch subs to 2 ohms
Hello familia_gome,
Those MOFO-15's have dual 1ω voice coils. So the only way you can get 2 of them to present a 2ω load is to use 1 voice coil on each one with the two of them wired in series. Using both voice coils, you can get a 1/4ω load by wiring the voice coils in parallel and then wiring the subs themselves in parallel. You'll get a 1ω load with the voice coils in series and then parallel the subs. Or you'll get a 4ω load with both the voice coils and the subs in series.
Here's a link to Power Acoustik's PDF for the MOFO's. I recommend that you check out the wiring diagrams on page 3.
http://www.poweracoustik.com/SUPPORT/MANUALS/PA-MOFOWoofer.pdf
Hope this helps.
Posted on Apr 07, 2009
etirbynnor
  • 655 Answers
SOURCE: How do i wire two fifteen inch subs to 2 ohms
Hello familia_gome,
If you have 2 subs that are 2 ohms, the final impedance will be either 1 ohm if they are wired in parallel or 4 ohms if they are wired in series. You cannot get a final load of 2 ohms. Unless your amp is stable down to 1 ohm (many amps are not), your best solution would be to wire the subs in series, positive of one sub to the negative of the other sub, and the remaining positive and negative to the amp. Yes, this will result in a 4 ohm load and the amp power will be reduced. But it is better than destroying your amp with too low of a load, and the subs will work fine, just not as loud.
Posted on Apr 11, 2009
  • 1126 Answers
SOURCE: Ohm calculations; 4 and 8 ohm sub woofer?
+ output from amp to + input of 4 ohm to + input of 8 ohm AND - output from amp to - input of 4 ohm to - input of 8 ohm is a parallel circuit = 2.66 ohm impedance load for amp
+ output from amp to + on 4 ohm - on 4 ohm to + on 8 ohm - on 8 ohm to - of power amp is a series circuit = 12 ohm impedance load for amp. Clear as mud??
Clear as mud?
Posted on Jun 11, 2009
How to wirea pioneer a pioneer tsw121 sub from4 ohms to 1ohm
That sub have dual 4 ohm voice coils, so it can be wired for either 8 or 2 ohms. It CANT in any way be wired for 1 ohm. Here is a diagram to wire it for 2 ohms.
Dec 09, 2013 | Pioneer Car Audio & Video
How to wire a crossfire vr602 2 channel amp at 4ohm and 2ohm
I would be more worried about the amp than the speakers, those subs should handle the watts with no problem. The problem will be in the amps ability to remain working with a bridged 2 ohm load. It may not even stay on without going into protect mode with a 2 ohm load. If it does stay on then it may get really hot and shut off from the heat off of the Mosfett Transistors, or it could burn the Mosfetts from driving them too hard. Basically it's your choice, run your amp hard and gain more volume or run it with slightly less sound and have a cleaner sounding more stable amp that will stay on and have less chance of being damaged. If it's not loud enough the best thing to do is buy a different amp that better suits your needs and fits the application. In your case a 2 ohm stable Mono amp is going to be your best bet or a 4 channel amp bridged into 2 channels and run with 4 ohms on each channel. Or another exact matching amp like your 2 channel amp bridge them both and have each powering 1 of your 4 ohm subs. I used two VR mono amps to power my two 12" 4 ohm subs for a few years
Apr 03, 2013 | Crossfire VR602 Car Audio Amplifier
I have 4 mtx 9500 12in subs 2 of them is on a mtx 92001 and the other is on a mtx 4001d . would it be better to run all four on the mtx 4001d. for more power and a better sound or how should i run this set...
NEVER mix different power amps. Depending on the ohms of your subs, sell one of the amps, up to you. The 4001 has more power, but either amp will do the job, the amp needs to see a 1 ohm load, so your subs have to be dual 2 ohms, or single 4 ohms to do this. If your subs are dual 4 ohms then you will have to run your amp at 2 ohms which would be have the power, or a half an ohm, (Not Recomended) and be at double the power. You may be able to do a competion sound off and just "Burp" the subs, but at a half an ohm, dont expect to listen to it to long before it goes into protect and shuts down.
Sep 06, 2011 | MTX Thunder Elite TE4001D Car Amp
What would be the best size amp to purchase for two audiobahn aw1200 subwoofers and two pioneer 4-way 6"x9"?
First, I would purchase the amp based on the subwoofers alone. Allow unit power to run the 6x9's unless you are planning a intricate setup. Things to think about when buying your amplifier. Always get an amp that offers an RMS output of 25-30% greater than the combined RMS output of your subs. Also, the stability of the amp to handle ohms loads (1, 2, or 4 ohm stable). If you have two dual 4 ohm subs you can get a 2 channel 2 ohms stable amp, or a monoblock 1 ohm stable amp. This will get you the most power and sound for your buck. There are so many amplifiers out there at different price levels, it's really up to you. Hope this helps.
Sep 03, 2011 | AudioBahn AW1200 Car Subwoofer
ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL...
From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
Specifications
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 100Wx2
    • 2 ch: (2 Ohm) 200Wx2
    • 1 ch: (4 Ohm) 400Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 250Wx2
    • 1 ch: (4 Ohm) 750Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Hope that helps.
Nov 08, 2010 | Pioneer PRS-X720 Car Audio Amplifier
What would be the best amp to push 2 kicker 15 L7s
find the ohms on each subwoofer and how much it can handle. If you have two 4 ohm subs get a powerful MONO AMP and hook it up in parallal. If you have two 2 ohm subs get a (1 ohm stable) Powerful MONO AMP and hook it up in parallel or a powerful 2 CHANNEL AMP but the wiring can be a little complicated cause you've got to connect the subs in series and bridge it on the positive of 1 channel and the negative of 2nd channel for maximium benefit without burning out the 2 channel amp. If you got two 500 Watt subs then you got to find an amp that can put out 1000Watts anything less wont sound good and may burn out the subs because of too much distortion cause of lack of power.
Apr 06, 2010 | Phoenix Digital PD-397 Car Amp
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Mar 27, 2008 | Pioneer TS-W301R Car Subwoofer
Prsx720
The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
Mar 15, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Pioneer prsx720 wiring question
If the subs are dual 4 ohm voice coils, you could hook the DVC's of each sub in parallel ("+"'s together, "-"'s together) making each sub essentially 2 ohms. Then connect one sub to each channel of the amps. This will put about 200W on each sub.
Mar 14, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Pioneer TS-W3004SPL Premier 12" SPL Component Subwoofer with 3000 Watts Max. Power Car Speaker Logo
60 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
