Question about Coleman Retro Rechargeable Battery Powered Lantern Family Size
Where can i get replacement tubes for coleman lantern.The replacement tube no is 5344b706
3 Suggested Answers
joboo1
  • 257 Answers
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Posted on Mar 16, 2009
CarlGlas
  • 283 Answers
SOURCE: Coleman rechargeable lantern: Charged overnight -
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Posted on Jul 21, 2010
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
Where buy ETU HS s11w 6500k Tube Fluorescent?
Hi Alex...
The most trusted site is amazon (for buying parts and items), so I have found this Amazon com 11w 6500k Tube Fluorescent
take a look, and see which one fits. enjoy
Apr 28, 2014 | Coleman Cable Twin-Tube Fluorescent...
Can it handel rain
It probably was designed to withstand exposure to rain but I wouldn't drown it to find out
Jul 02, 2013 | Coleman Cable Twin-Tube Fluorescent...
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
Nov 22, 2011 | Camping, Backpacking & Hiking
I cant get any petrol to pump into the mantles
If the petrol doesn't come through first check that you have enough in the tank. If the tank is not full enough it won't come through. If it still fails to come through it's likely that the generator is blocked. This is the tube which the mantle sits on and it has a very narrow opening to force the petrol to convert to vapour when it's warm. Try heating it for a while and it may clear it. Otherwise you'll need to buy a new generator.
Note: while the dual fuel lanterns can burn petrol you should be aware that it gives off poisonous fumes, like cars did before they had catalytic converters. The lantern should not be used indoors with petrol. They are safe with coleman fuel. If you live in the USA, Coleman fuel is cheap but if you're in Europe it's much too expensive. Rather than buying a new generator, if you live in Europe, you could buy a parafin burning lantern like the Petromax 500 available from http://www.pelam.de/index.php?cPath=28_31&language=en&gclid=CIOe46DQnqYCFQkf4QodQxz2Zg
and other sites, or you can pick up second hand Optimus lanterns on Ebay. Both burn parafin, though they need to be primed, and provide at least as much light as the Coleman.
Jan 03, 2011 | Coleman Northstar Dual Fuel Lantern
I have a Coleman 228F model lantern. When I go to light it, it barely produces any gas. I have made sure it is pumped adequetly and full of new fuel. I can hear gas coming out very faintly and sometimes...
It's likely that it was left away with fuel in it. This causes gel to form which blocks the fuel getting through. The blockage could be anywhere between the tank and the mantles. The order I would check in are;
  1. The feed tube assembly
  2. The generator
  3. The Burner
It's possible to get these parts from coleman or coleman suppliers. To find which needs replacing you'd need access to another similar lantern and try replacing one at a time. Otherwise it's going to be trial and error or just replace all.
There's a manual which shows the assembly and the order number for parts at http://www.coleman.com/coleman/images/pdf/220f_228F.pdf
I hope this is of some help.
Dec 16, 2010 | Coleman Sport & Outdoor - Others
Cant figure out how to take apart to replace bulb
More information is required in order to answer your question. However, the following link will take you to the Coleman website for battery powered lanterns. www.coleman.com/coleman/parts/product_category2.asp?category_id=170
Jul 19, 2010 | Coleman Rugged Battery Powered Lantern...
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman Retro Rechargeable Battery Powered Lantern Family Size Logo
159 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Ted Maxwell
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
