Question about HP Compaq nc6000 Notebook
DVI to VGA connection problem
Hi all... the monitor I use for my htpc has just died. I'm attempting to use my work laptop (nc6000) as a monitor for my htpc (very) temporarily. I have a DVI to VGA cable that I have connected from my htpc's graphics card DVI out to my laptop's VGA. I thought function + F4 might enable my laptop to display my htpc signal. Is this at all possible, or is the VGA connection on my laptop an out (only for use with projectors etc)? Any help or suggestions would be much appreciated.
    Sergeant:
    Champion:
  • 304 Answers
well have you try to restart the laptop first..? -or- did you have test it first..?
`jack
Posted on May 24, 2008
  • Elizabeth Krijt
    Elizabeth Krijt May 24, 2008
    - well it will not work.. to use your laptop monitor to connect it & use it a secondary monitor..
    Sergeant:
    Champion:
  • 230 Answers
I think you can use it only for the projectors etc and you should not use as monitor by this way
Can I hook up a HP L2245wg monitor to a Hp envy laptop
Probably not very easily. The monitor only supports VGA 15-pin and DVI-D video connections. Although you don't specify which ENVY model you have, most only have HDMI and/or DisplayPort outputs. You would need an HDMI-to-DVI-D adapter/converter for the video, and, of course, DVI-D and VGA do not support sound, although it appear the monitor does not internal speakers anyway. You would be better served using a monitor with HDMI input(s) with this device.
Oct 17, 2016 | HP Computers & Internet
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Connecting MSI M670 laptop to Dell U2412M Monitor
There is an adapter VGA to DVI, I suggest going to a computer store to locate one.
Mar 07, 2012 | MSI M670 Notebook
Why is the dvi connection not working wih the monitor or do i need a hdmi connection?
On the laptop, did you "enable" video-output to the DVI port?
Most laptops have 3 modes:
* output only to the internal LCD screen
* output only to the external VGA/DVI/HDMI port
* output to both internal and external ports.
What manufacturer of PC laptop?
What model-number?
The key-sequence for choosing the mode depends on which computer you have.
May 22, 2011 | Computers & Internet
I have a VGN-FS630/W and i am trying to use an external monitor, brand Envision, i got it working but it got disconected and now all i get is a White screen on my external monitor and my laptops screen...
Hi there
regarding that issue that you are having with the external monitor is not working with your sony vaio here are some steps that might help to have it working
connection between the monitor and laptop
- VGA ( blue adapter ) or DVI ( white adapter )
- check if the connected properly
- try to use a different VGA cable
- check if the monitor is detected by the computer
***please also do a monitor selftest on the external monitor***
- HDMI
- check if the tv is detected by the computer
- check the settings of the TV for the HDMI
hope this helps
Jan 11, 2011 | Sony VAIO VGN-FS630/W Notebook
Over last 3 years screen has become progressively darker, particularly on the left hand side. It's difficult to see. I was thinking about buying a separate monitor, but not sure what cables I would need to...
Sounds like a backlight problem. Backlights can be replaced but it all depends on the make/model of laptop you have. Connecting an external monitor to your laptop also depends on the type of connection you have on the laptop.
Most (if not all) will have a VGA output which requires a standard 15pin VGA cable. Newer laptops might have DVI or Mini-DVI. Some even have HDMI. So ultimately, the type of cable you need really depends on the type(s) of output your laptop is able to display and the types of inputs your monitor supports.
Dec 03, 2010 | Computers & Internet
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Dvi port doesn't work with 23'' samsung monitor
yeah, you can set the display setting as extension display your DVI
Intel, ATI,Nvidia have tools also to set up,
i have ATI and use the ATI Catalyst tools and autodetect the monitors that i connected to my docking station, intel and nvidia also have this utility.
it depends on setting if u wanted the external monitor as CLONE monitor of your laptop or extension Monitor...
or they might have problem on DVI port of your docking station.
download and install the video utility ( must have .net installed before you install the utility)
the utility will detect your video ports (VGA,DVI,S-video)
let me know the update ..
Mar 23, 2009 | HP Compaq 6710b Notebook
Cannot show laptop image on external monitor via Svideo connector
If you want to use your TV as an external monitor, you have to connect them via VGA (top) or DVI (bottom) cable.
Which connections does your Philips monitor have?
Jan 05, 2009 | Computers & Internet
Trying to connect Acer X213W monitor to Acer 3613 laptop. First Q-My laptop does not support 1680 x 1050 resolution, can I still use the monitor?Second Q- I can't seem to locate where to connect (hardwire)...
1. Yes, the monitor will just display the resolution set by your laptop.
2. There should be a VGA port on your laptop, it's a trapezoid shape with 3 rows of 5 holes and usually blue. Since your monitor only has a DVI cable, you need to get a DVI to VGA adapter to be able to plug your monitor into this spot.
Dec 27, 2008 | Acer Aspire 3613WLMi Notebook
HP Compaq nc6000 Notebook Logo
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
