Question about Ovens
I have bought a Bush AE56TW cooker but the grill pan supplied is not wide enough to slot into grooves in the grill cavity. It appears you have to use an oven shelf and theres only two supplied. Can I get a grill that just slots in like all other cookers?
barkencoa
  • 3463 Answers
SOURCE: how can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
  • 4102 Answers
SOURCE: Smoke comes out of grill on electric cooker
hi, what you will probably find is that the grill over time has got grease on it and other contaminents from food you have cooked in the past the best thing to do is turn the grill on full and let the smoke burn out open windows etc as it will stink the whole place out it may take a while to get hot but just wait leave it on full and you should find it will burn off all the grease etc and then it will stop smoking.
If you turn it on full and then you get nothing happen after about 10min then turn it off and you would then need to think about getting the element replaced.
Let me know how you get on or if you need further assistance ok
Posted on Nov 10, 2009
barkencoa
  • 3463 Answers
SOURCE: how do i know if im useing the grill or my cooker
If you are using the grill,only the element at the top of the grill compartment will get hot.
Hope this helps.
Posted on Jan 12, 2010
tbreeze47
  • 3083 Answers
SOURCE: We have had the following
The most probably and likely thing that is happening is that you have a bad pilot, and it's shutting off the gas valve. I'm not sure which model you have, but the following site has good troubleshooting information to help you:
http://home.howstuffworks.com/how-to-repair-an-oven6.htm
Read the article, and it will inform you of the possible causes, and what action to take.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 05, 2010
  • 14 Answers
SOURCE: the grill on my Hotpoint EW 41 Electric
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Posted on Jun 12, 2011
Testimonial: "thanks for that mate"
Bush ae56tcs the oven has suddenly stopped working. The light and fan isnt going on either. Everything else on the cooker is working (ie the grill and hobs)
-Check the breaker on the electric panel. Possibly two legs breaker, one pop out but still one on. you still have power but can't cook.
Good luck
Mai Lor
Nov 08, 2014 | Ovens
What would happen if fan is disconnected noisy and not wanted?
NO NEVER EVER DISCONNECT FANS OR ANYTHING ELSE ON YOUR COOKER.
Your cooker may have at least two fans, one for heating the oven cavity and one for cooling the electrics etc inside the oven. If the fan is noisy, check to see the fan has not come loose on the motor (maybe left had thread) if the fan is ok, then the fan motor may need replacing!
Oct 20, 2014 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
Jun 12, 2011 | Hotpoint Ovens
Daughter had cooker delivered today,is this model surplied with cable.
If it is a single cavity built in cooker, then they are usually supplied with connecting cable, but if it is a full size cooker, then it is not normally supplied with cable,
Mar 18, 2010 | Ovens
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Feb 17, 2009 | Zanussi ZHQ575 Electric Double Oven
How can i mend the grill and oven on my electric cooker?
Hope this helps.
Thanks.
Dec 31, 2008 | Ovens
Beko DCC4521w cooker grill element
it is done from the rear and inside cavity.Can be supplied approx £24.00+p&p,Check old element for continuity.
Sep 14, 2008 | Ovens
Ovens Logo
129 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
