Question about Bosch WFK 2401
Replaced the brushes on my Bosch WFK 2401 last night. Ran a spin cycle empty and all appeared well. Tried to run a load of clothes and instead of spinning up slowly, it seemed to try to spin fast for a few seconds-accompanied by a loud screech and an arc! Any ideas?
  • Bosch Master
  • 3,463 Answers
Sound like a prob with the control board controlling the motor, could be expensive .
Posted on Sep 28, 2010
  • tracy950 Sep 28, 2010
    Could I have done something while replacing the brushes? Everything seemed to go back together very easily, brushes making good contact, etc. It seems that similar posts have experienced the same problem (noise, arcing) after brush replacement.
  • Barry Coates
    Barry Coates Sep 28, 2010
    You may have put the brushes in the wrong way round, try reversing them , as it can make a big difference.
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
I replaced the brushes but machine still does
it may be the belt is loose, can you hear the the drum trying to turn? if so its the motor, take the belt off the motor and see if you can spin the rotor it should spin easily
Feb 17, 2010 | Bosch WFK 2401
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Bosch WFK 2401 problem, please help
this could be a block in the pump or motor brushes would go for the pump
Jun 22, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Drum will not rotate or spin
oooops - the motor was stuck under the carriage. Once
moved it came off easily.
Jun 17, 2008 | Bosch WFK 2401
Washer won't agitate
this sounds like it is a relay on the module (main pcb) if the carbon brushes have been fitted correctly then there is a fault on the module, these items are replaced as a unit, i would also look to see if the machine has a capacitor fitted, this also could have the same effect and would be a much cheaper repair to start with, a capacitor is normally situated at the top where the mains wire enters the machine, its normally about 2 inches long and 1 inch round with 2 wires from it, work with safety unplug before doing anything
Sep 09, 2007 | Bosch WFK 2401
Washing Machines Logo
481 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
