Question about LG LRSC26915SW 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, LED Display & Hidden Hinges: Sm...
What is the part number for the water line hose, clue the one that is a 5/16 O.D. size
    President:
  • 1,796 Answers
Hi!!
Check this site to identify and order your part. http://www.repairclinic.com/
Don't forget to rate this post!!!
Posted on Sep 28, 2010
Testimonial: "fast and accurate responds."
Missing hose, 1/8 approx size, one end connects in back of intake air flows out where does the other end go?
Not much info but It can only go as long as hose so look 360 deg around for the open line it goes to or part. note the curves bent in hose for clues
Not sure if this will help. Hope so. Mike
Feb 19, 2016 | Cars & Trucks
Bosch washing machine leaks
what size is the line you are using for the gray water. what i mean is if you are trying ti use the same size hose as the original discharge
hose, the pressure to high. the hose original was about 1 inch diameter, the hose use to go up than the hose hook shape goes into the drain pipe thats 2-3 inches diameter for draining the water went into the sewer system, if your trying to use 1-1/2 hose, the diameter not enough air or room for all that water. i dont think the lenth the issue its the diameter and amount of pressure that being forced down small hose or pvc pipe.
Oct 06, 2015 | Bosch Washing Machines
What size water line do I run for my kenmore all freezer ice maker
If it's a new in-wall run to it, standard 1/2" is fine. From the wall to the freezer you can do 3/8" or 1/2"
An ice maker doesn't use a lot of water so you can consider it a low demand system. If you're connecting from wall to freezer most hardware stores have premade hoses; just like the water hoses for a washer or a toilet.
Jan 24, 2015 | Kenmore 18.6 cu. ft. Built-In All-Freezer...
Water frozen under ground how do i UNFREEZE IT
The only way I have ever used successively is using a water hose with water as warm as you have access to. A regular garden hose hooked to your water heater clean out cock at the bottom of the tank will give you 60 to 80 gallons depending on it size. even cold water will work but take longer. Push the hose in till you hit the ice and open the water up all the way. it will splash back out of the fitting you use to access the line and may take quite a while depending the length of the frozen water line. Good luck. Its usually a messy job.
Jan 10, 2014 | Plumbing
I just bought a Bosh Ecosense dishwasher. I need to know size of the water supply line and drain hose?
The size of the water supply line is 3/8th inch (10mm)
The drain line is 7/8th inch (22mm)
Oct 10, 2011 | Bosch Dishwashers
I have a model 109163. I'm trying to pump water from a creek. The suction hose is about 6 ft below the pump and 12ft long. The output hose is running about 300 ft at a gradual incline to about 10 ft. My...
In order for the pump to **** up water, it must discharge air. Try this. Install a hose bibb (faucet) in the discharge line over top of the pump. Fill the pump housing with water, turn on the pump and open the hose bibb/faucet until full water flow is established. Almost all air should be out of the pump and suction line at this time. Now when you close the hose bibb/faucet, the pump will have plenty of pressure to fill the long discharge line.
Suction line should be 2-1/2 inch if that is the pump suction size.
What size is your discharge line?
There should be a check valve/foot valve on the end of the line in the creek to keep water in the pump once it is primed.
Gary
Dec 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
I need to reinstall awater inlet valve on my
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com go here,put your model number in and hopefully this will help you,next time you need help send the model number,good luck,just take off one line at a time and install it into the new valve,the lines are different sizes and the solenoids are colored so it's kind of hard to do this wrong,also there should be instructions with the vavle
Jan 10, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Leaks from a hose coming out of water pump and wraps around behind engine. what hose is this?
That hose appears to be your heating hose.On that line the warm water goes in to the cabin and makes your radiator warm,same size hose should be there as well as the water comes back on that one.
Jul 17, 2009 | 1999 Ford Windstar
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
